Brake Pedal Height?
14 posts Started 14 Mar 2023 Last recovered post 19 Mar 2023 Wayback Machine snapshot 21 Mar 2023
Hi Folks,
According to the Service Manual the Brake Pedal Height is supposed to be 67.5mm (2.66").
What is that height in relation to?
It doesn't matter much. Put it in the location where you can use it best/safest. Levers/pedals set to factory settings are usually quite far off from where they are most useful.
18 hours ago, bmart
What is a "normal" amount of travel when depressing the lever before you feel the pads engage the disc?
20 hours ago, wawasonqo
Hi Folks,
It refers to Push Rod Length.
See this from the Rear Brake section of the Service Manual!
[image: 20230315_074209.jpg]
Again, depends on the rider, their footwear, shoe size, butt-on-seat location, amount of air in system, clip-on location, caliper piston cleanliness, etc. I just looked in my owners and service manuals and do not see any spec. I have seen them in manuals for other bikes, but it is a starting point, not afinal adjustment location.
Ride the bike to determine if the lever is low or high to get onto when you need it, and if the pedal location is adequate for how much brake you want to have available in the amount of movement you are comfortable with.
There isn't a "proper setting" on this bike or any other. Sorry!
And some pics of where my '98 is and the moviement to actuate...which is minimal. I hope that these help!
[image: 20230314_220059.thumb.jpg.0900ec6cb45036fb2ed200ef6e68fe2d.jpg]
[image: 20230314_220112.thumb.jpg.08d55d6f6179d5c9ef294a02bb759001.jpg]
7 hours ago, Grum
Thanks, I missed that.
Seems to check out.
2 hours ago, bmart
It looks about 1 cm at the front of the pedal, about the same as mine.
Will bleed the brakes.
At present, application of the pedal is not achieving anything. The wheel still turns and there's no modulation I can feel through the pedal.
I delinked the brakes with a kit from the UK with Braided Lines and at the time after doing that it appeared there was never much strength to the braking on the rear disc. I would have thought that with the 3 pistons all being activated together that there would be a noticeable difference but it seemed "dead/wooden" in feel. The front brakes in comparison only require 1 finger for most braking.
If I recall correctly, back in the day, some folks, who had delinked their bikes, replaced the master cylinder with one from a CBR600F3.
So, any ideas regarding this are most welcome.
bmart, 3/14/2023 at 9:08 PM
Mine has always had the barest of travel, even when new so never messed with it but sometimes wonder if it's doing anything, unless stomping on the rear brake when not pulling on the front.  Only then can I tell the rear brake is working.
6 hours ago, interceptor69
Are your brakes still linked?
2 hours ago, wawasonqo
Yes-stock except for several set of new pads over the years.
wawasonqo, 3/15/2023 at 4:31 AM
Do you have a link or name of that delinking kit?
1 hour ago, toreckman
It's in one of my posts for the following Topic:
Rear Brake Bleed (Delinked/De-linked) - Caliper Mounting?
toreckman, 3/18/2023 at 7:56 AM
HEL make a kit.
End of thread · 14 posts recovered Wayback Machine snapshot 21 Mar 2023
