If you used the breaker shipped by Roadster with your 020, it's almost certainly the auto-reset type. IDK why he uses those. IMHO they're crap. I ditched mine for a 30A replaceable maxi fuse.
Also, if you do replace the stator, swapping to a 6th gen stator and flywheel is a nice upgrade. Prior to doing mine, at idle when the cooling fan kicked on my VM was reading below battery voltage - and I have LED headlights, so my base current draw is very low. My stator is (was) low mile and checked out fine. After the swap I get around 13.5 with the fan running and 14.5 (as before) going down the road.
A couple of things to note if doing this:
1. Although the 5th and 6th gen blocks share much in common, stator covers are not one of them. You'll need to retain your 5th gen cover.
2. The 6th gen stator will bolt right in directly to the 5th gen cover, however the stators are NOT the same thickness. IIRC (it's been a year now) the 6th gen stator is slightly thinner, thus the 5th gen bolts will bottom out in the blind hole before drawing the 6th gen stator down tight. DO NOT keep tightening the bolts b/c the stator remains a bit loose lest the threads strip, ruining the cover. Get some slightly shorter socket cap bolts and torque them to spec. Do some measuring to satisfy yourself that you've accounted for any differences.
3. To get the 5th gen flywheel off, best bet is to use an impact gun. Rent or borrow if necessary. Holding that little beastie in place is a real PITA, even if you do have a strap wrench or similar to place around it. It might be doable with 2 sets of hands, dunno about that - I did mine solo. Impact gun makes quick work of it. I kept it on the lowest setting that would remove it to minimize the shock load to the crank.
4. If the flywheel is a no-go coming off the crank snout, go to an auto parts store and pick up a 20mm X 1.5 oil drain plug. It should thread easily by hand in to the center of the flywheel - do not force it. If not, check the plug threads or possibly you have the wrong size. Once it bottoms, use a wrench to tighten, then the flywheel should pop right off. The plug should cost $2 to $3, not the $20+ on Amazon or $$$$$ from Honda.
5. The 6th gen flywheel has two flats on the hub that I could fit a large adjustable wrench on (which the 5th gen flywheel lacks). That made applying the 76 foot pounds to the bolt a breeze. So for me this became a one way trip - once the 5th gen flywheel was off I was committed to the 6th gen, as I had no way or re-torquing the 5th gen flywheel. I do not recommend re-torquing the flywheel with an impact gun. That's one of the critical fasteners that needs to be correct - close may not be good enough.
6. The "V" shaped grommet on the 6th gen stator wiring was larger than the V groove in the cover - it required some trimming. Since I had the new stator re-wound, IDK if that was because they used something different than OEM or if there's a difference in the two covers which need a different size grommet. Regardless, I did some trimming. My trimming work wasn't perfect, so I used a skim coat of silicone and have had no leaks in the 1,000 miles I've been running it.
7. If your gasket breaks apart when removing the stator cover, be sure to use only plastic scrapers. Use of a steel scraper will surely scratch the aluminum and you'll have leaks. After 25 years, removing the gasket was difficult - the best thing I could find to soften it was acetone, which actually did a pretty decent job. From what I hear, the EPA has pretty much neutered most gasket removers we have today. Gaskets are NLA from Honda (as are 5th gen stators), but there are sources on ebay that will do fine. I applied a thin film of grease to the gasket to make future removal easier.
When doing this swap, I followed the lead of others that have also done it. I was skeptical - I did a lot of measuring to see if there were any clearance issues with the 6th gen flywheel. I used modeling clay to check for clearances whilst assembled and applying bluing to various places that looked like could be problematic. Everything came up ok. Once assembled, I turned the engine over without starting it, the took it back apart to see if there were any signs of rubbing, scraping or interference. All looked good. Be sure you are satisfied that all is good before the 1st startup.
Overall I'm very happy with it - the output is definitely improved and so far it's been a seamless swap. YMMV
