Any fellow '99 owners can help me with understanding key blanks?
10 posts Started 14 Nov 2024 Last recovered post 18 Nov 2024 Wayback Machine snapshot 19 Nov 2024
Hey guys, when I bought my '99 (me being the third owner) it didn't come with a spare. I've been looking for an OEM key blank (with the Honda logo and everything) so that I can go to a locksmith and get a spare made. Partzilla is telling me that 35121-KW3-771 is the key blank for my bike, but it looks much shorter than my normal key. I believe that 35121-MN9-611 is the right one, but I just wanted to check with you guys to be sure that the spare isn't supposed to be shorter or something. Also, another question, the key code is the 3-digit alphanumeric code under the gas cap right? Mine follows the format of [number][letter][letter]
[image: image.png.50cbc5fd3e52fc239615d2c25a596d0f.png][image: image.png.b333cfe59d2aa096a4e69428e68dfb64.png]
I'm looking to make myself a spare as well. Commenting here to follow
35121-MN9-611 is the correct part number. I just bought one from WeBike in Japan , I can confirm it works/fits perfectly. I also believe if you dismantle the helmet lock you can find the 3-digit key code there too.
I have 2 '99's. 771 is the spare key for both bikes and is identical the original key.
Sounds like both will work.
Good info!
Out of curiosity, can any key cutter around town cut these, or do I need to go somewhere special?
Any real key cutter / locksmith can (should be able to) do it by the number.
Just had a spare key cut for the 2001.
Locksmith provided the blank and copied my key, which was not oem, for $10.
Said that copying it from the key code, which I had, would be $40 using the same blank. Guess its more involved for the same result.
My experience is the same as Captain & FromMaine. My 2003 RC came with one original key and one that the PO had made at his local hardware store. The hardware store key actually works a little bit better!
For ‘95 my local charged $60 to cut from code, works on/off fine but won’t operate steering lock plunger feature of OEM switch. Tried an “online” cutter service from Germany first($25), waited 2 months for it & got a useless result(sent code & pics, etc.)
Tirso, 11/14/2024 at 7:21 AM
[image: 20241114_020520.jpg]
Huh, interesting. So it looks like my hunch that the spare key is short was correct. Good to know that they would both work though.
End of thread · 10 posts recovered Wayback Machine snapshot 19 Nov 2024
