I took the occasion of the Chistmas days off to finally implement my plan to get my VFR as adherent as possible to my personal idea of VFR
Let's start with the main thing: I'm definitely in love with G4.
G4 embodies my idea of what a VFR should be: elegant. refined, sporty but classy and most of all... not reduntant.
That's the thing: G5 is a wonderful machine, indeed; the engine is lovely, and it has decent tire size on rear, but its layout is... too much
VFR concept does not need fancies like D-CBS, PAIR, flaps and so on. VFR has to be pure
So, here's my work on my G5 to get it "leaner".
The initial part of the job has been done at the very first moment I put the old guy in garage: flap removal, PAIR removal and small things more.
Here's the post
Once done this, the rest of the plan was:
- D-CBS removal
- Ignition coil update with coilstick
- Front indicator removal
1. D-CBS removal
I made what most of all already did : VTR1000F front-end swap.
I found a second-hand fork set, and a complete braking front system (including a HEL steel braided line)
[image: large.20240921_164831.jpg.8f6b51dbdc6c58068a5ceb24beaf2d42.jpg]
I won't add pictures of the works, because it's something posted dozens of time here.. I just want to remark an upgrade: a dedicated forkbrace, designed by myself: and machined from a solid Avional 2024 block.
[image: image.thumb.jpeg.6a5867f96de837b4889daacc8ab07f6f.jpeg][image: large.IMG-20250113-WA0048.jpg.b31e0504184d03173644c3416ea4cf3f.jpg][image: large.IMG-20250113-WA0047.jpg.3654c46c95500670d3b5a3021f8d3193.jpg]
I replaced the original spacer with a new one made in aluminium:
[image: large.IMG-20250113-WA0034.jpg.8b474cf3fdb59f30f3b22bff99b3bf50.jpg]
Here's the frontend swapped in:
[image: large.IMG-20250113-WA0023.jpg.fb0238a684e3befd125c5d74040567b1.jpg]
Because I use it "solo only" (my wife has her own bike), I removed passegers footpegs.
I'm still studying for a decent muffler bracket...
[image: large.20241005_162950.jpg.9842edebc52462789f5e9e059d65dcc0.jpg][image: large.20241005_162933.jpg.dbb67f47581460bc21aa2f45d79ea5a0.jpg]
2. Ignition coil update with coilstick
As well as the frontend swap, it's something posted a bunch of times here,, so I just want to thank you all for inspiration and information.
Despite all the info collected here, I fell into the error to buy a short coilstick 😁
However, it's not been completely useless, because by applying the seal of the shorter into the longer I got the perfect match:
Short and long:
[image: large.IMG-20250113-WA0030.jpg.fed151b037118d42a4656ed9e1365652.jpg]
Long coilstick equipped with seal of the short coilstick: 👍
[image: large.IMG-20250113-WA0011.jpg.22d8b8f79d30316d82a0604151f5c5e2.jpg]
Front cylinders:
[image: large.IMG-20250113-WA0041.jpg.2c2a8aa1ff9d52f33e891483e7ab2703.jpg]
Rear cylinders:
[image: large.IMG-20250113-WA0015_2.jpg.1a0a6e26537ffd16b84e7696a976083c.jpg]
In the end, I replaced the mirrors with a pair or units with led light.
[image: large.IMG-20250113-WA0039.jpg.56c73b89de407a204216bc51a2ad0196.jpg]
They're very light (supports are in plastic... 😣) so I'm not totally convinced; I wait for the response of the road to finalize this mod.
Initially, I closed the holes with an aluminium grid, cut with the proper shape.
[image: large.IMG-20250113-WA0040.jpg.5889971433f502f0eaae3f74a1e1c2e0.jpg][image: large.IMG-20250113-WA0044.jpg.308a8ee9bd0f544d10ff484b2a813de1.jpg]
I have another choice by closing these holes with the proper caps from Thurn:
[image: spacer.png]
Once on the road I'll decide what I like the most.
To close this long and boring post, here's the video of the first start-up 😊
I willingly avoided to post all the pictures of the job here.
For those who want to peek in, here's the link of my gallery:
Just one thing is missing: footpegs rising.
Thanks for watching 😀
