Just want to share my progress on delinking my bike.
I got some suggestion / ideas from this forum on how to cope with the 'bracket sub. assembly' aka 'front left brake caliper mounting bracket including a secondary master cylinder'.
One suggested to fixating the pushrod of the secondary master cylinder with some kind of epoxy and another suggested to make a bracket between the fork leg and the two mounting holes which normally hide the SMC from sight. Epoxy... not my thing here.
This was my go at it the bracket between fork and interface near SMC:
[image: image.thumb.png.49ebb9bcbbc011cf5c6ec13fe6e81fed.png][image: image.thumb.png.2150f5c1ad53b42f424133f04a79d1d1.png]
(also credits to FreeCAD, love that software!)
In short, I wasn't happy about how 'off center' the bracket is vs. the force that it will receive during braking.
Next to that, these two M6 bolts, they don't give me that warm feeling if they receive 250 N - 400 N.
I considered a rod that replaces the moving parts in the secundairy master cylinder on which the pushrod could be fixated:
[image: image.png.cb5bba56d8178c47e5ac6648d3d2aa5b.png]
(pushrod to be attached on left-top, right slides into the cavity of the master cylinder and circlip would hold the rod into the cavity)
Which could have worked and would have been cheap.
But, it would 'act' a bit differently since the opposing force would not be from brake fluid, but from hard contact in the 'cup' of the cavity of the master cylinder.
Next to that, why not make a full replacement in which I would be able to slide on my original brake caliper...
Well, for starters I would need to reserve engineer the bracket regarding mechanical distances / offsets / volume. A lot of effort.
So, I started looking for Honda models that also applied the same 'generation' of Nissin brake calipers (which also would have CBS).
Which I did via lookup of caliper parts on cmsnl.com.
I ended up looking at a Honda CBR1100XX from 1997 - 2006, which proved to have 'moved out' the secondary master cylinder from the front left brake caliper mounting bracket, lovely!
[image: image.thumb.jpeg.5b95df51e1f3eb3f358d0863efc91916.jpeg]
But unfortunately, after receiving a second hand, the mechanical offsets did not come close to the VFR800 (3.5 mm difference of caliper placement in the direction of the wheel axle)...
[image: image.thumb.png.8b995fcb4b30735e4a77b4d400361e59.png]
(next to that, there seemed to have been an issue with the motorcycle, since below is very abnormal wear):
[image: image.thumb.png.953eca35e25118297ad5b24175ffd650.png]
So, back to square one on how to tackle this. More tomorrow!
