http://www.vfrdiscussion.com/forum/uploads/1168234710/gallery_491_2526_234678.jpg
Measuring coil length on the short side of the spring
Let me begin by addressing a few items first as to why post this in the first place. One reason is to do what I always do, (being the cheap bastid I am) - why spend good money on a spring you can make yourself for a fraction of the cost! Assuming of course you need a stiffer spring! You know you do because you changed your fork oil, its spring like weather outside and it is warm, you set your sag to 1/4 - 1/3 of the total fork travel to the optimum sag for a vfr (I split the difference) and of cours to answer the question below!
I finally sent my forks in to Aftershocks. They've told me a few things that I'm having trouble understanding and thought to get forum advice.
1. Rather than putting in new springs, they can modify the progressive springs I'm currently using (by cutting off the "progressive" section) and this will give the same desired end result.
($50 to cut off part of old spring vs $110 to put in new springs)
2. Age of the spring does not matter, springs actually get better with age (my current set of progressive springs have something like 17k miles on them. My old stock springs have ~25k miles on them)
3. Stock springs are typically better than aftermarket springs b/c the stock springs are "heat-wound" (or something like that) while most aftermarket springs are not.
4. Cutting off coils on the stock spring (~0.74?) can somehow modify them to a 0.95 spring rate and this will somehow be better than using new aftermarket springs that are speced at 0.95.
How can cutting coils get a better spring rate? Wouldn't this mean they would cut the coils and put spacers in? Wouldn't this reduce my fork travel? If springs get "better" with age (assuming better means consistently maintaining their spring rate), then why do I need to crank my pre-load tighter and tighter as they age?
So, if anyone has had their springs modified and can attest to successful results, I'd love to hear about it.
Cheers,
Zohar
Los Angeles
98 VFR
06 Triumph S3
total for travel 120 mm / 3.5 = 35mm
Wow so you checked it like I show you here and you end up screwing the preload all the way too the top! Something is wrong here! I guess your too darned fat for the vfr :goofy: heh just like me! What do you do ? You have kids to feed! ~ and a wife who needs money for groceries! Here is what you do, you cut the stock springs down to size - thats what! You will need some tools but your a guy and guys have tools right! (well so do women who ride)
Now how do you figure out what the spring rate really is? You can look it up in your shop manual, according to everybody at vfrd your springs should be rated at 0.74 kg/mm! There is a simple way to measure it yourself! Vfr springs are steel! Go get your wifes bathroom scale, without pissing her off about it - or buy your own! And put it on the floor, clean up the fork spring first (not oily or rusty!) and get a tool you can push down on it with and keep it in line, like a shaft of a large screw driver! Thats how I did it!
First measure the total free length of the spring!
http://www.vfrdiscussion.com/forum/uploads/1168234710/gallery_491_2526_149378.jpg
Measuring the Spring Free Length Amazing its exactly 15 inches pretty darned close anyway.
You would think they got them from the USA?
http://www.vfrdiscussion.com/forum/uploads/1168234710/gallery_491_2526_65210.jpg
Pushing down on the spring using a large screwdriver I stop at 10 lbs tape now reads 14 3/4 inches or so
I use this as my baseline measurement and then I push down on it more to add more weight to the scale!
http://www.vfrdiscussion.com/forum/uploads/1168234710/gallery_491_2526_141882.jpg
Pushing down on the spring more I pushed on the spring till the tape moved 1 inch from the free length reading 14 inches
It was a difficult to take a picture and do all this so I just took the photo to demonstrate then did the actual measurement after I put the camera down, the spring will want to twist up on you which is why you need a long shaft to hold it. I ended up pushing in the spring one inch and getting the scale to read 40 lbs!
Take the difference in weight
40 minus 10 = 30 lbs
Take the difference in length
14.74 minus 14 = 0.74 inches
OK simple calculation gives you the spring rate in empirical scale
30.0 divided by 0.74 = 40.54 lbs/in spring rate
convert that to metric using conversion constant (looked up on the internet)
40.54 divided by 56 = 0.72 kg/mm
wow thats pretty close to the book! And too weak for my fat a$$! I found this chart from Race Tech (vfrd members 15% off BTW)
http://www.vfrdiscussion.com/forum/uploads/1168234710/gallery_491_2526_43678.jpg
Race Tech Diagram spring rate recommendations
According to that chart I should be using a spring rate of 1.1 kg/mm?? Jebus I already bought the 1.0 and those are stiff enough for me! - But this writeup is about you not me! I think race tech is too stiff for road applications, great for riding at the track but the street its too stiff. Me I would go with 0.9 kg/mm if I had the chance to do it again! Been there done that see here! If I could I would do it again!
How do you do that with stock springs! YOU CUT THEM SHORTER! But not without calculating how much! to get from .72 kg/mm to 0.9 kg/mm the calculation is rather strait forward surprisingly! Just figure out the percentages!
0.9 minus .72 divided that by .72 = 24% holy moly!!!
you need to cut off 24% of the coils to get a 0.9 spring rate? Or you could just settle for 0.8 kg/mm or 10% cut off! Is that even doable what if you cut it off too short? How do you know! Me I read Mark Lawrence's page on doing it and and he shows the calculations, sort of like doing your taxes but its not too difficult!
http://www.calsci.com/motorcycleinfo/Suspe...easeForkSprings
There is also a page for calculating any steel spring rate! besides breaking out the bathroom scale!
I took the measurements 26 coils, diameter .2 in outside diameter 1.2 inches = 52 lb/in divide by 56 = .928 kg/mm WRONG! doesn't account for pitch!
http://faq.f650.com/FAQs/ShocksSpringRateF...te%20Calculator
Calculating how many coils to cut
Back to cutting the springs! Now we need to figure out how many coils we can safely cut using Marks calculations it goes like this!
(a) Spring wire diameter - 5 mm
(b )Number of coils - 26
© Total free length of the spring 375 mm (13 inches)
(d) Spring binding length a * b = 130 mm
(e) Available spring travel c - d = 245 mm
(f) Travel per coil (average) e / b = 9.423 mm
(g) Fork tube travel (manual says) 120 mm
(h) Excess spring travel e-g = 125 mm
(i) Excess spring coils h / f = 13.26
(j) Number of widely spaced coils: count 18 (dual rate spring)
(k) Number of coils to cut j * 24% (from above %) = 4.376
(l) Length of widely spaced coil measured 16.61 mm
http://www.vfrdiscussion.com/forum/uploads/1168234710/gallery_491_2526_64267.jpg
Measuring coil length center to center on long side 16.61 mm or so
(m) Length of stock spacers measured: 50 mm
http://www.vfrdiscussion.com/forum/uploads/1168234710/gallery_491_2526_155036.jpg
Measuring stock spacer 2 inches
(n) Length of new spacer (k * l) + m + plus a safety margin 10 mm = 138 mm
add 10 mm in case you cut the springs too short and you cant achieve sag, you can always cut the spacer shorter!
(o) Desired Dynamic Sag g / 3.5 = 34 mm
(p) Saftey margin (excess spring - length to cut off) h - (k *l) = 53mm
Now to actually cut off 4.4 coils off! Me I would use my cutoff wheel then grind it off at the end - heating up the coil with my torch to flatten the edge. and your done, some use PVC 1 1/4 inch pipe for spacer material, I use aluminum pipe, or brass pipe even would work.
Attached is a microsoft excell spreadsheet I made with all the calulations above - easy cheesy
Quote
Howdy,I finally sent my forks in to Aftershocks. They've told me a few things that I'm having trouble understanding and thought to get forum advice.
Cheers,
Zohar
Los Angeles
98 VFR
06 Triumph S3
Attached File(s)
[image: Attached File]
forkspring.xls (21K)
