I'm not sure if I am one of the first to put the VFRness on a 2000 VFR, but Tightwad was looking for some fit / finish information for how the kit worked on the 2000/2001 models and I promised him I would take notes and post a quick how to. Overall, the product is well made and Tightwad was helpful in answering a few of my dumb questions.
I still need to ride around on the bike for a few hours with the new harness just to make sure all is OK (don't ask...work has been hellish) and I also want to check for the signal wire issue and check the charging voltages. I haven't had any R/R problems yet (knock on wood) so I don't expect any issues post install.
Sorry is a few of these steps are "duh" in nature...
Remove the seat.
Remove the tail fairing (six allen bolts and four wire harnesses to the tail lights)
Remove the battery box cover.
Disconnect the battery wires...watch the little nut on the bottom side of the connector!
The R/R is located on the left side of the bikle under the tail fairing. This should be pretty obvious once the fairing comes off.
Remove the two bolts holding the R/R in place. be sure to watch for the nut on the back to fall off, or be prepared with a long, twisty magnet to retrieve them when they fall...ask me how I know that one.
There are two wiring harnesses coming from the R/R. You only need to unplug one of them...the clearish colored one. Leave the white one connected.
I also took the time to gently push / prod the stock wiring harness as much out of the way as possible. You can see here I zip-tied the harness to the frame rail. Take a few minutes at this point to clean things up, wipe off dirt, and generally try to straighten up anything which looks "hangy" or loose.
Plug in the connectors of the VFRness...one goes into the factory plug, and the other goes toward the R/R. They will only fit one way. Now it's time to start thinking about where you want the extra wires to route. Honestly there isn't a lot of room to play with, and I recommend playing with a few options until you get something neat and tidy with no kinks in the wires. I guess you truly don't have to unbolt the R/R completely, but I think it helps to have that loose to play with wire route options. (The two loomed wires in the center are the new harness.)
Step 1
Step 2
Step 3
Tightwad recommends bolting the harness ground to the R/R itself...I'm sure to save some wire and some space. I double checked the ground there and it was present as long as I scraped a little paint off things to get a good contact (although the wire has a ground through the harness anyway...I also found). You could perhaps grind some paint from the sub frame and make a new ground if you like.
The "extra" 20 amp fuse has plenty of wire to be put somewhere you feel comfy with. I chose to put it more or less right next to the stock 30 amp fuse. (Don't forget to change the 30 amp fuse to the supplied 20 amp fuse.)
I also purchased the access plug panel, and with the Sargent Seat I had plenty of room to install it just aft of the battery box. Install is pretty easy...the purple wires connect the relays to each other...then just wire up pos and neg to the battery terminals.
Getting the extra wires onto the battery terminals using the stock screw took a little effort. I stuck a small pick under the nut on the terminal so it would be held up high enough to allow me to start the bolt and cinch everything up. I also had to trim a little of the battery box cover away to make it fit over the new VFRness wires.
Once you get that done, you're done. Check to make sure all the electrics work and the bike starts. Do the charging test (as recommended by Tightwad and many others here...) and then put everything back together.
I will update this post with my charging test results and the sensor wire fix (if necessary) as soon as I get a chance.
If I missed something, or you have questions, please chime in.
Remove the seat.
Step 1
Step 2
Step 3
