Twin Exhausts For A 1998 Vfr800
Could we ask why you want to do it?
Well, I'll bet you it's not because he hates the idea of it... :offtopic:
What type of setup do you have in mind? Underseat(like the VTEC), one per side left/right(low, mid or high mount?), shotgun style(left or right side, staggered or not), change the headers to pair front and rear or left and right banks, etc, etc....
Lots of options. Pick a style and we can help you from there.
I'd hazard a guess and say looks.
Knife,
I've yet to see a complete kit for a dual exhaust ready made for a VFR.
But with a shop capable of cuttinng and welding, the sky is the limit... :thumbsup:
I had an Akrapovic made to fit on my 4th gen, how about a Yoshi?
I found there's not enough room atop the swingarm on the LH side for a second can and associated bracketry.
The chain guard and chain run would foul the can at even part compression of the rear suspension.
Besides that, the only practiceable way to route a pipe over to that side is to run it under the swingarm and chain run, and that would compromise cornering clearance. Going up and over the rear tire to the LH side, there isn't enough room up in there.
You could adapt a VTEC tailsection and obviously the exhaust along with it with some welding of the subframe. I don't think anyone's done that yet.
There have been companies that made dual shotgun pipes for the 5th gen. Devil was one. Mig did also. And so did Indigo.
I think all of them are discontinued now though. http://www.vfrdiscus...tyle_emoticons/default/sad.gif
And then there's this:
How do the RC45, RC30, TBros 3rd-4th Gen accomplish the left hand exit? It seems the general geometry of the bikes are all the same, there must be a way to route a left hand exhaust for the 5G? :offtopic:I found there's not enough room atop the swingarm on the LH side for a second can and associated bracketry.
Tailsections must be different on the RC30/45 as to the clearances. Made higher from the factory?
Also, the RC30, IIRC had a large "divot" in the exhaust, a sharp kink at the lower chain run to allow the pipe to tuck in closer.
I placed my Micron can, as a test, EXACTLY in the mirror spot on the LH side from where it normally sat on the right, measured from several points on the tailsection, and there was about 2 inches at the closest point from the can to the top of the chainguard. And that was on the centerstand.
Like this, but obviously on the other side:
Hit a small bump and the chainguard would be occupying the same real estate as the muffler.
You could move it outboard, but it would have to be about 3-4 inches to make a difference. Would look silly hanging out there in the breeze.
Either that or move it WAY backwards, with the can outlet significantly aft of the taillight when viewed from the side.
THAT would look like those ridiculous Easy Rider fishtails sticking into the next county!
I think the can sits quite far outboard of the tailsection.
Of course, theres nothing on the right side to match up to. My goal was to have them symmetrical.
BTW, there was only one cool dual exhaust bike in that movie. :offtopic:
I could use some advice. Is it possible to change out my 1998 VRF800 single exhaust for a dual set up? If so, is there a kit available, or is it necessary to fabricate what's needed and adapt someone else's exhaust? Has anyone done this? Thanks.
I'll be perfectly honest, I want to do this for the look. Underseat (like the VTEC), or one per side left/right (high mount). I'm open to suggestions. And thanks to all for such quick responses!
