I was, we hit 85 here this week and the VFR started getting mighty toasty in stop and go traffic. I have bitched before about the stupidity of Honda's puller fan design on the left side rad.
For me the scenario is something like this.
If I'm cruising around at more than 20 mph, my water temp is 195 or less.
As soon as I get into stop and go driving, the temperature will begin to creep up. It will go up pretty darn fast if I'm stuck behind one of the city buses or next to delivery truck where you can just feel the heat pouring off the other vehicle.
Now once it hits 225 the fan switches on and the fun begins. The temperature does not go down, instead it will continue to creep up, In fact just the other day it went all the way to 230 before the light changed and I turned onto a side street so I could get out of traffic and move some air through. As soon as I get moving more than 25 mph and can keep moving that fast, the temp will come down. I have repeatedly checked that the fan is turning at full speed and even stopped to feel the heat being blown out the front of the bike.
So while I was on lunch Thursday, I wandered back into the Honda parts aisle to the section where we have cooling fans. I had a halfhearted hope that I could score a replacement fan for a vtr1000f. I was basing this choice on several facts. One the fans share the same locking nut on the shaft, they were specified as the same diameter, the motors are supposedly the same size and spin in the same direction.
Well we had one and since it was just sitting there on the shelf I bought it to put my own eyeball on the problem.
I had nothing really important that I could do anything with this afternoon,.. So I broke out the tools to see how hard could it be?
Well here are the pictures.
Here is the original stock Honda fan with the locknut removed from the shaft.
[image: gallery_5886_3799_56205.jpg]
Here are the two blades side by side with the motor above
[image: gallery_5886_3799_65981.jpg]
Here is the VTR fan blade slid on the shaft waiting for me to smear some paste locktite on the shaft threads
[image: gallery_5886_3799_69351.jpg]
And another shot of the new fan inside the shroud and the old blade next to it. You can clearly see here that the VTR fan blades move the air in the opposite direction of the VFR fan. [image: gallery_5886_3799_69191.jpg]
On pair of photos with the Honda packaging in the background so you can see and get the part number. [image: gallery_5886_3799_65484.jpg]
[image: gallery_5886_3799_30542.jpg]
I yanked out the pair system while I was in there and installed the block off plates from our own Toro1. I don't know about the rest of you, but the inside of the covers and the hoses was coated with a black oily film. I bet that was not good for power or emissions either!
Anyway I put it all back together, then started the bike and pretty much just let it sit until it was warm enough to engage the fan. Even in the still air of the garage, the 225 temp immediately started to drop and in minutes it cooled off enough that the fan switched back off. Yeah the heat blowing back from the left side was noticeable, but it was not excessive nor did it last very long.
I let it cycle like that a couple of times while I did things like lube the chain, adjust the throttle cable, inspect the welds on the sideracks, etc. After three more cycles, I shut it off and declared it a sound victory.
IMO, this is how Honda should have done it all along.
