[image: View Post]crazybrother, on May 15 2008, 09:35 PM, said:
[image: View Post]Tightwad, on May 15 2008, 02:36 PM, said:
Somewhere I saw a picture where someone had a pipe fabricated to do away with the catalytic converter. Can anyone recall where that was? I was thinking with all the 2000+ models that wish they didn't have them, it should be possible to arrange a group fabrication to cut the individual costs....and with all the genius on this site I bet someone here could even make them!
I haven't looked under my bike....does the cat bolt on at both ends, or is the Cat-back all on piece? Pictures there would help as well!
The Cat is connected to the Head Pipes, you would have to cut & weld a new pipe on the replace it. Great Idea, I wish that someone would make one & sell it to us. I would buy it :pissed:
HEY ENGINEER/FABRICATORS!!! :fing02:
Since I'm not, test my theory (bear in mind who it's coming from... :dry: ).
1) cut open bottom of cat; maybe while on bike.
2) remove cats
3) fashion a 'slip joint' type of unit to expand to fit the voids once in place.
4) use proper clamps/sealant to tighten in place.
This way, everything stays aligned, and the stand rest and attachment points remain. :fing02:
There would be no stress on the joint since the upper 'catcover' would remain intact.
I could see this done on a core exchange, or you order the part and DIY.
What do the 'Wrenchers' out there think? :idea3:
Greg
Most of all, the system is STAINLESS, it seems a waste to not make use of it and it would keep the costs down!
