Exhaust Diagram
[image: View Post]Mr. Horsepower, on Sep 14 2008, 06:21 PM, said:
so i am trying to figure out what the inside of the stock 07 vfr 800 muffler looks like. does anyone have a diagram or a link to one. basically i am looking for an image of how the can is set up internally. routing of internal pipes and baffles and such...can anyone helpI want to know, too!
IIRC, it was in one of the MANY "exhaust gut" threads for the 6th gen.........
(n I ain't going looking for it, sry!)
Three chambers. The exhaust passes a screen into the first chamber (closest to the front of the bike), then through a pipe to the third chamber (closest to the rear), then turns 180 and goes into the middle chamber, then turns 180 again and out the actual pipe you see coming out the end of he stock can.
No pic, but I hope this helps.
PM Kanadian Ken as I think he might have a diagram.
[image: View Post]sckego, on Sep 17 2008, 11:13 PM, said:
Find the exhaust gut thread started by Rice. He had a great diagram of what it looks like.[image: Posted Image]
hope some of those helped, its all I've got. I'll be gutting another one this winter - I'll take some better pics then.
Got the same question.when people drill them out what part are they drilling??? i know you just basically shove a long drill bit into the exit pipes and drill away...is there a better or easier way to do it...???
Please any one knows put some mark-up on the diagram showing where to drill, how deep and actually the modification hole would be made from which part to which parts?
Thank you.
What you're actually doing is removing a small section of the last exhaust pipe so that the air, rather than flowing back into the middle chamber and out, can go directly from the first chamber out.
You are removing this section in the circles, and the arrows show the airflow.
There is a step-by-step instructional thread, but basically, you drill out the weld that holds the exit pipes in place by drilling with a 1" whole saw around the outside of the pipe, then with a small cut-off wheel, you cut the exit pipe from the inside and pull it out.
In HERE, they mentioned about "drill" some holes "at the angle"... and I believe that is drilling on the muffler.
There is a diagram showing the "drilling" on other bike exhaust:
yeah i figured someone would have done that...i looked through a ton of the threads and still have not seen it...if anyone is more familiar with the thread or if you were the one that made the sketch can you please post here...thanks
Use Google search, it works a lot better than ours IMO! Just add ,VFRD to the end of the search and it pulls things up nicely! :fing02: ie: "Gutt 6th gen VFR exhaust, VFRD"
Thanks Ryan for the obvious explanation. That way is more on gutting the muffler.
No, I am referring to the "no gut" solution. So that we're all on the same page, and not arguing over definitions: Gutting the muffler involves sawing off the end caps, removing everything, and then reattaching them.
What I'm referring to is removing a small section of the outflow pipe by drilling into the muffler and using a dremel.
Here is the original thread: "New Way to Gut" thread
Is this what you're asking about?
I agree, use Google to search this site. But the correct way to search and get only VFRD info is to use this search format - "Gut 6th gen VFR exhaust site:vfrdiscussion.com"
Use the "site: ~~~~" to limit your results to just one web site.
