Okay, everyone is proud of their new Staintunes and custom paint jobs, and rightfully so. But let's see what kind of stuff you came up with for little or no money that improved the comfort, appearance or just made your bike easier to live with.
Here's my weather proof registration and insurance card holder I made from a cut down tube a gun barrel came in. You can buy these at hardware stores too, but free is always better and good for 5 hp. I used some parachute cord I have to make a lanyard and some kind of goop in a tube to glue the cord to the tube. The other end I put around the brake line and super glued the ends together. If the tube should come off the velcro I stuck to the frame, it doesn't get lost. Just stick some velcro to the frame and the tube and you're done. I thought this up because no one wants to think about taking their seat off when you have a ton of stuff strapped down while you are loaded up on a trip, and carrying your paperwork in your wallet is not very weatherproof. It's also darn near invisible unless you know it's there.
Has your 6th Gen got balls? These are the balls that are on the handles of tools like drill presses and such. They also make a cheap frame slider that will protect your tail piece and exhaust pipe in the event of a tip over. Balls and button headed cap screws are $11 at Ace. I had to drill the hole in the foot peg bracket out to 1/2", but that was only slightly bigger than the hole that's already there.
My 6th gen, being a proper lady... she certainly does not have balls. I want to ride her hard and fast, not throw my leg over a he-beast with giant black balls.
Here is my "low cost" modification - a piece of metal angle welded to the side stand. Allows me to park anywhere from hot asphalt to wet sand without looking for a beer can.
codeMonkeyMy 6th gen, being a proper lady... she certainly does not have balls. I want to ride her hard and fast, not throw my leg over a he-beast with giant black balls.
You California guys sure are comfortable with substituting (insert favorite inanimate object here) for women whenever you feel the need for...ummmm...shall we say..."adventure", aren't you? :goofy:
You California guys sure are comfortable with substituting (insert favorite inanimate object here) for women whenever you feel the need for...ummmm...shall we say..."adventure", aren't you? :dry:
I'm working on one now and will post pics in a couple days when it's done. The total cost will be about $10.
For the 5th Gen riders, Sargent Seats come in a two piece design that allows you to use the rear cowl cover as a bigger trunk area without the passenger portion of the seat. Corbin also has a similar offer in a one piece single seat design. Instead, I picked up a second hand stocker and cut the back off and stapled the cover back down. Add to that the quick release pins replacing the Frakenbolts, and it is easily accessible! Can't find any pics, looks completely stock with the cowl in place. Stock seat suits me fine, without needing to spend the big bucks on an aftermarket!
I really like the tool knob idea.....I used Parts Unlimited Bungee Nuts in the holes. Can be used for bungee cord tie downs, and protrude past the bodywork............... :unsure:.......
Item #1 up for bid: Visor Wiper. Cheapie 1/8" cutting board, some hot glue and velcro wire ties. Latest change: add velcro to clutch MC and cut the velcro band down, instead of strapping to the back of my left hand.
[image: gallery_1632_2886_59976.jpg]
Wiper blade
Item #2 up for bid: Cup holder. 1/8" aluminum bar stock (from a 19" network/telco rack filler plate). Cut to bolt down to the gas cap ring faux mounting bolts. This gas cap ring has two mounting bolts on a tab so I can switch between a homebrew camera mount or my cup holder. As seen at WDGAH:
I've been meaning to do this mod for a long time because I've always thought chrome is for cruisers.
Anyhow, I wanted to keep my stock cans because I don't like loud motorcycles. However, I never liked them being chrome (or stainless steel, whatever it is.) A can I always thought looked cool is the Two Bros. VALE can. Consequently, I decided to duplicate the look.
After removing the heat shields and tips, I sanded them down to the bare metal. I left the shields alone and then painted the tips black using my trusty rattle can of high temperature paint (you can get a can of PJ1 engine and case paint from most dealerships for $10). Sanding the heat shields sort of gives them the brushed aluminum look you see on the shields of the RWB VFR. However, from a distance (or at quick glance), they can sort of pass for Ti.
All these pics were taken with my cell phone (hence the poor picture quality.) Since I already had the rattle can, all this mod cost me was about a day's work and the cost of the sand paper. As usual, I welcome all comments, positive or negative.
here's something else i did with the same rattle can and sand paper. i repainted the heat shield next to the right foot peg assembly because some of the factory paint had started to flake off it. it was kind of tricky to remove and even trickier to reinstall, but i made out okay.
I'm going to mount some on my wife so I have something to kick when she complains about my bike.
SEBSPEEDChopped spare set of pegs and painted satin black:
[image: gallery_5444_1301_33003.jpg]
Interceptor 068.jpg Chopped pegs
[image: gallery_5444_1301_180145.jpg]
Beauty shot
Did you do that to have a monoposto look with the hard bags on? I like to take mine all the way off when I don't have the bags, but now that i've got an ABS I have to have them there to attach the preload adjuster. I want to do the same thing though to show off the SSSA!
todduluDid you do that to have a monoposto look with the hard bags on? I like to take mine all the way off when I don't have the bags, but now that i've got an ABS I have to have them there to attach the preload adjuster. I want to do the same thing though to show off the SSSA!
Yes and no. I didn't like them blocking the wheel, so I was going to remove them, but then bought a second set and chopped them so I could use the hard bags and have the wheel show. I switch back and forth between the two, depending on whether my wife comes with me or not.
SEBSPEEDYes and no. I didn't like them blocking the wheel, so I was going to remove them, but then bought a second set and chopped them so I could use the hard bags and have the wheel show. I switch back and forth between the two, depending on whether my wife comes with me or not.
This looks really good, and is my favorite mod in this topic so far. I took my pegs off, and routed the preload adjuster to under the seat... but it takes up space and is hard to adjust. Plus, it hurts my hand to lift it on the center stand without the grab bar.
If you have a minute, i would really appreciate more info... Could you share a bit more on how you accomplished it? - What did you cut with, What paint did you use, How much did you pay for your spare pegs, Do you have a distance shot before you painted the handle? THANKS! :fing02:
codeMonkeyThis looks really good, and is my favorite mod in this topic so far. I took my pegs off, and routed the preload adjuster to under the seat... but it takes up space and is hard to adjust. Plus, it hurts my hand to lift it on the center stand without the grab bar.
If you have a minute, i would really appreciate more info... Could you share a bit more on how you accomplished it? - What did you cut with, What paint did you use, How much did you pay for your spare pegs, Do you have a distance shot before you painted the handle? THANKS! :biggrin:
Sure, I cut the peg off with a bandsaw, cleaned up the rough edges with a grinder, then bead blasted them and sprayed them with 3-4 coats of Rustoleum Satin Black. I got the pegs from a member here, I don't remember the exact amount, but I remember it was a little more than I had hoped for. Keep your eyes on ebay. Not sure if I have another shot, think I do, but I would have to dig around.
There are some good "Farkles" on here.This might not be all that great or even a "farkle". But for keeping my registration and insurance card with me when I ride and dry. I just put it in my helmet between liner and shell. It works for me.
I liked the look of the bike without the chainguard while I was changing out my chain and sprockets last Spring. So I left it off and just used a piece of aluminum, bent it at right angles, drilled a few holes in it, and hooked it up to the brake lines to keep them from hitting the chain. Cost me a whole $4 making this bracket.
[image: gallery_12318_3774_486505.jpg]
[image: gallery_12318_3774_282167.jpg]
[image: gallery_12318_3774_664194.jpg]
[image: gallery_12318_4009_46416.jpg]
I plan to get the ss braided brake lines and running them through the swingarm for next season though.
Okay, here are some pics taken outdoors with my digital camera. Although I think they came out good, if I could do it over again, I'd use medium and fine sandpaper not heavy, medium, and fine. The best thing to do is what Travis did and simply sandblast the parts.
The only winter project I've got planned is to do something about the cheap paint Honda used on the subframe. I still haven't decided how to tackle it so I'm definitely gonna do a search on this forum to get some ideas. At that time, I might sand the shields one final time with ultra-fine sandpaper.
[image: Posted Image] Picture 069.jpg
[image: Posted Image] Picture 068.jpg
[image: Posted Image] Picture 067.jpg
[image: Posted Image] Picture 145.jpg
Damn, that looks good; I've always hated the look of the chaingaurd. I hope you don't mind me copying your idea... 'cause I'm gonna!
You've done an outstanding job taking care of my one big complaint with VFRs (most gens): big, heavy-looking tail-sections. Once you get the lines through the swingarm (something I'll likely do this winter too), you're gonna need a prettier wheel, 'cause you'll sure be showing it off!!
I've never quite had the nerve to get rid of the chain-guard completely. I have visions of something getting dragged into the chain (I know, not likely). So I made my chainguard out of a free piece of L-channel aluminum:
[image: Posted Image] Mistresses.jpg
That aluminum chainguard looks good. You did a great job on that. Can't wait to put lines through swingarm too.
Sorry, I haven't got my bike at work with me today, but a couple of cheap farkles I've done are to remove the "air guide" from below the swingarm (WTF is it for anyway?!?), the centre cap from the hub, and bought some chromed Honda Civic wheel nuts to replace the standard dull VFR ones. They're practically the same size, just slightly different taper on the inward end. I wasn't game to remove the chainguard even though it's ugly, as too much chain spooge finds its way around the bike as it is.
Another no-cost farkle that was on my bike when I bought it was cutouts in the tail cowl so I don't have to remove the pillion grab handles to fit the tail cowl. I had to enlarge these slightly with a laminate trimmer though, as the handles are higher than stock due to the Ventura pack rack I fitted.
I also have the unique VFR800Canuck 'racing' lightened footpeg brackets that he kindly gave me to replace my bent ones. They were cheap - cost me ~NZ$30 to be shipped on a SlowBoatViaChina (8 week trip, IIRC). Thanks Rob! :fing02:
End of thread · 30 posts recoveredWayback Machine snapshot 28 Jan 2023
