Safety Wire?
I hope you have a drill press, or a pre-drilled drain plug. Use a hose clamp around your oil filter to wire it, or use a K&N which has a hole in it already.
Get the safety wire pliers, makes the job much easier!
Bolts are pretty hard so bring plenty of bits, you'll likely break a few. The K&N 303 filter has the hole thru the nut on the end that makes it real easy to wire up.
Im Doing a trackday at Barber in july and although It is not required for novice I am looking for a predrilled Kit or just the side case bolt and oil drain bolt predrilled if possible.
I suck at drilling anything and dont have the tools for something like drilling a bolt head..
I found a predrilled Oil Fill plug and caliper bolts at http://www.tastynuts...te/frameset.htm
I plan to send them a Email asking about the other bolts but if any of you know where to find them that would be very helpful.. Tasty Nut is in the UK across the pond..
Any one with the tools to do this I know of 2 people in need of these items..
What's the purpose of a hole in your drain plug? What do you wire tie it to something to prevent it from losening?
I always thought a saftey wire was something to kill the bike should the rider fall off. I think I have seen holes in kill switches for that purpose, but now I'm not so sure...
you are thinking of a dead man's switch.
http://images.google...htt...sa=N&um=1
2. As safety wiring is standard procedure in the aircraft industry, go to an outfit called "Aircraft Spruce". Their website is: http://www.aircraftspruce.com When you go there, type in "Safety wire drilling jig" in the search box. This is the neatest little jig for holding all different sizes and types of bolts for drilling for safety wire. Done properly (slow drill press speed and lots of lube), you can drill lots of bolts with the same bit.
Unless that is a left-hand threaded bolt, that will never pass tech inspection. Actually, there are several examples on that web-site that would never get a signature from an A&P.
I'll agree with that, if you have the right equipment... But for the average guy, in his garage with a drill press, not wanting to make a mess by slinging cutting fluid all over, high speeds and light pressure will yield much better results. A lot of "pecking" with the bit will help keep the chips clear and stop binding and breaking.
Honda bolts are "dished" in the middle. Don't even attempt to drill right on through. You will have to drill half way from each side.
I don't remember where I saw the original of this. But here is a nice fixture I built for corner-drilling nuts.
The blade-shaped handle of the oil fill plug can be easily drilled, and Honda has conveniently left a small ear around an adjacent engine-case bolt that can be drilled to serve as a safety-wire anchor. Next, a large hose clamp will need to secure the oil filter in place. Simply locate the clamp mechanism next to the engine case to prevent the oil filter from rotating.
I'm sure Timmy took that picture as a bad example, and rewired that one immediately after. Or, he was playing with photo-editing software and flipped it. :blush:
EDIT: Now that I looked at the image source, it's from RC51.org, so go figure. We knew Timmy was smarter than that!
I just used the first safety wire photo I came to on google images. That one there looks like it would turn almost 1/2 a turn before the wire would do anything, and the guy didnt twist it.
better example:
