5th Generation Sprocket Guide
24 posts Started 1 Oct 2009 Last recovered post 14 Dec 2012 Wayback Machine snapshot 27 Jun 2017
Okay but you have an 6th gen???
Am I missing something?
6th Gen chart got Pinned (see top of page in Modifications Forum). I did it first.
BR ask me to do the computations for a 5th Gen also. He is suppose to pin this post. Don't know why he hasn't yet.
what can i use this information for? i dropped a tooth on the front per BR's advice and i still love it.
da9b20what can i use this information for?
The purpose of both of the charts I put together is to try and give empirical answers to "if I drop one here and add one there, etc" how will my scooter be affected, blah, blah, blah. That same question gets asked 100 times on this board. I figured it was time to do the calculations so everyone could see what the effects are. I was getting frustrated by the vagueness of statements such as "going up two teeth on the rear is equal to going down one on the front", etc, etc.
For instance, if you do the 16/45 mod, your new 6th gear is pretty well going to be equal to a stock 5th Gen's 5th gear.
It's empirical information for anyone contemplating changing their sprockets. They can see exactly what the effects will be.
Pete McCrary6th Gen chart got Pinned (see top of page in Modifications Forum). I did it first.
Cool, that was the bit I was missing.
Thanks Pete
I think it has something to do with him being in the hospital with two broken legs. Not sure that's the exact reason, but it sure does sound like a good one.
Don't worry, I only have a broken ankle and separated shoulder, so I pinned it. :fing02:
We'll all just have to wait at the next turn for Bailey, he's bringing up the rear. :blush:
veefer800canuckDon't worry, I only have a broken ankle and separated shoulder, so I pinned it. :fing02:
Thanks Veefer!
Any chance of 3rd and 4th gen tables?? BTW, t'would also be cool to know how many links the stock chains are for each model... :fing02:
Att the moment I sitt and wounder if I will get stock 17/43 or 17/45 for my 5th gen.
I would like second a bit lower in twists, spechally 2 up, but I will go a lot commuting next season, so how mutch will it effect fule economy?
keny
I would suggest the 45(ever 46 if you 2-up a bunch) rear for sure and unless your slab the whole way at 90 mph I doubt it will effect mpg much at all! :biggrin:
keny
I switched to the 17/45 set up last summer and am still averaging 41.8 mpg (17.7 km/l) on my '99.
BaileyRock
:idea3: You won't be dissapointed. The gains outweigh the losses (ymmv). :fing02:
Well I seem to have a odd problem, no shop or importer have a 45 thoot sprocket in stock in my country!
I was going to change them early next week.
So I´m in to ither stock 17/43 or go one down front to 16/43.
I was also planing to rise the rear a bit by shiming the upper shock mount. Going down one on front sprocket and riseing rear end, will I have my chain rubbing the swingarm all the time? :wheel:
keny
I was also planing to rise the rear a bit by shiming the upper shock mount. Going down one on front sprocket and riseing rear end, will I have my chain rubbing the swingarm all the time? :fing02:
I run the 16/43 on my 5th gen and don't see that(raised rear) as an issue. :fing02:
Math Check...
so the increase from 17/43 to 17/45 is 4.453%, and that translates roughly to 6267 instead of 6000 RPM in top gear? That isn't much change. One of the reasons that the mileage isn't hurt much or at all is because the engine is running slightly "easier" even though it's spinning a little faster. Sounds like a decent change.
For the increase of two teeth in the rear, does the new chain need to be +2 links from the stock chain length (don't remember that count off hand)?
BaileyRock
Ok, thanks for the info. I have to order a 16/43 set then.
Where does the speedometer read the bike's speed from? Is it the front axle, the front sprocket, rear sprocket, rear axle..? Is the odometer from the same place?
number9
Speedo runs off front sprocket, odo is the same signal.
So any gearing changes throw off the signal to both.
Veefer800Canuck
number9
Thanks! I don't think I can see my front sprocket to count its teeth. Is it a pain to remove the stuff that's in the way?
Edited April 19, 2010 by number9
Try a new approach :)
http://www.vfrdiscussion.com/forum/index.php/topic/72914-custom-cush-drive-for-vfr800-vfr400-axle/page__hl__+part%20+deux#entry860030
End of thread · 24 posts recovered Wayback Machine snapshot 27 Jun 2017
