Need to replace the horn - plan to put in a good pair of hella's or bosch. The problem is the ideal location. Any suggestions ...with images will be of good help.
Don't know about those, but the Stebel Nautilus Compact Motorcycle Air Horn will fit under the fairing on either side. A few have even mounted it in the OEM horn location.
I left my standard horn where it was, but tweaked the adjustment screw to make sure it was as good as it could be. The two Fiamms are mounted under each side of the front fairing, on very bent brackets hanging off the front fairing stay. I had to put thin foam rubber on the horns in case they rested against the fairing. It's tight, but works OK - just took lots of fiddling to get them mounted right.
[image: View Post]AnikMankar, on 10 November 2009 - 06:25 AM, said:
Thanks for your pictures. Nice spot but i already have HID blasters over there - i had screwed them exactly where you have put the horns.
Hmmmm.... see if there's room under the side fairings. On my '90 VFR there was no room up the front, so I had each horn under one of the side fairings, attached to the bottom radiator bracket. I know it's not the same as the 5th Gen, but the point is that if the horns are loud, you can put them basically anywhere - the sound will still manage to find its way out. :fing02:
Still struggling with this. I did put the Horn x 2 in the original place but since they are a little big, it hits the Front mud guard on a very bad road. The area under the upper Cowl is not a option anymore since i have the HID kit located there.
My bike's PO squeezed a Stebel Nautilus Compact under the left side of the top fairing. It fits (just) and is Stebel Nautilus Compact-loud! I'm sure I've posted pics somewhere...
End of thread · 12 posts recoveredWayback Machine snapshot 27 Oct 2012
