5th gen grab rails do fit. ^)
For the assembly you will need:
-5th gen VFR (with or without tail/exhaust/tank)
-6th gen tail&exhaust (get the Whole tail. Every part can be mounted)
-6th gen tank (I think it will work also with 5th gen. Didn't try)
-A professional welder. You and your "+1" will sit on it.. do I have to add smth else?
-A professional CNC'er (for the same reason)
Step 1: The bracket.
Due to the difference in the construction, we'll need to cancel the two upper mounting holes and construct a bracket that will hold our new tail instead. Here's the sketch:
* remark* the distance between the two holes must be 38mm instead 40.. My bad.
The Material.
The Yield strength of a material must be approx. 90 kg/mm2, to ensure you won't feel your rear wheel too close..
The materials available are 43XX steels (4320, 4340). I used 416 stainless steel, after cementation to 90 kg/mm2.
No need to tell, that all the parts are Argon welded both sides.
Step 2: The Spacers.
You can see that the 6th gen subframe's lower tubes are situated much wider then the original 5th gen. So, I placed the spacers between the tubes and the frame "ears". Dimensions: Outer diameter-25mm. Inner diameter-10mm. Length- 22mm. Each.
Choose any material you like.
Step 3: The Big Cut.
Yes, we're going to cut things!
First are the too long "legs" of the subframe, that we are going to cut in the middle.
[image: scetchleg.jpg]
As you can see in the sketch the "ear" is a bit inside the leg itself. It's very important to keep it so after we cut the leg. So, first remove the welding, then remove the ear from the tube, then cut it, then return the ears back, then weld. Use the long bolt from step 2 to ensure the ears are welded collinear to each other. I didn't do that..
The cut piece of the tube is 125mm long. But I leave these measurements to you.
It's better to cut less then more, cause you won't be able to bring in back.
Step 4: khmm..
All the stuff that was in the plastics of the old tail has to be moved.
Here's my R/R's new home:
