Rear Cowl Modification (solo seat)
36 posts Started 1 Feb 2010 Last recovered post 28 Jun 2010 Wayback Machine snapshot 14 Oct 2012
Hi
Anyone modified the rear cowl so the rear handle bars still stay on ? pictures would help. Not sure i want to start cutting the cowl before i know how its going to look.
Yes it's been done by others, I've seen pics, but sorry I don't have any handy.
I have a different Givi set up than timmy so ended up cutting a little larger opening. I've never tried to fit it with the grab handles though, I think you'd have to make a fairly large cut in the cowl. I picked up one cheap off eBay to cut up, left the original intact.
I've done the mod and will try to remember to get pics up for you, right now I don't have any and the bike is burried behind other projects. I'll see what I can do in the next couple of weeks to get some of them completed and the bike out. I did it with a Dremel, looks good with the handles in place. None the less, just have to take you time and just a little plastic off at a time, can't put it back on nearly as easily as it comes off! PM me if I don't get pics up as a reminder, might take me up to 2 weeks but after that, I've forgoten!
Mine was done by a previous owner, but I had to enlarge the openings slightly to accommodate the increased height of the grab handles after I fitted a Ventura rack (bolts on under the grab handles). I used a laminate trimmer - this cut so cleanly it left a nice edge around the enlarged opening.
  • [image: Left.jpg]
[image: Attachment] VifFerrari.jpg
Very neat job on the cutting. Looks nice. I think i am convinced to do the same. have to ensure i don't cut more :D
Project Completed.
Was difficult to stencil out the right cut. So i did make a sample "outline" using a hard board and then got the final cut on the Rear Solo Seat Cover. But All's well.
Thanks you all for your valuable inputs
[image: View Post]AnikMankar, on 01 February 2010 - 12:37 PM, said:
Hi
And why would you want the passenger grab bars with the cowl?
Hi
:comp13:
That's what I was thinking, I took my grab bars off the very first day I got the bike....they are useless for a passenger to hold on to   :goofy:
Quote
So's you can take a passenger without re-installing the bars?
[image: View Post]Paladin, on 06 February 2010 - 09:46 PM, said:
Quote
I guess you haven't ever been a passenger and tried to use those things...they're terrible!
Quote
First off, its very hard to hold on from behind, Second, If your giving a woman a ride, you'll want her arms around you. And I for one, do not give rides to males.
Quote
My wife uses them without complaint. Of course, if she were to complain, she'd wouldn't get to go. Posted Image
Well, I used the Grab Bar to put the bike on the Main stand - easier for me.
switching from having the cowl or not is easy...just have to take it off and then Vola its done.
I have tried sitting as a pillion on the bike and tried holding the bar - its not very comfy
You use the rear grab handles to put the bike on the center stand?? HOw tall are you, 7' 4"  lol   http://www.vfrdiscus...tyle_emoticons/default/wink.gif
not even me?
I think I am more closer to the ground ....5'7' http://www.vfrdiscus...tyle_emoticons/default/wink.gif   but it easier to use the handle bar. :
Next Project how to make it easy to take the Cowl out instead of the bolts. Has any one used any kind of PUSH TYPE clasps or something so taking that off is easy.
Sargent sells some quick release pins. http://www.sargentcy...wsvfr8.htm��You could probably find them cheaper at a local hardware store. They do require you to drill out the threads.
Quote
Indeed. It's easier to remove the cowl than re-install the bars.
In any case, my bike was like that when I got it. Apart from using the grab handles to wheel the bike around or to bungy things to when carrying stuff on the seat (which I've never done as I have a packrack), the handles aren't used. MY wife hangs onto me when riding, but only in the twisties.
If I took the grab handles off now, it'd leave ugly holes in the cowl.
Thanks this seems to be what i am looking for. Unfortunate I am in India and no Sargent here   :blush: .
Anyone here done this ...step by step   :fing02: with pics will help.
Got my quick release pins yesterday - they fit like a charm. Used the 3/16 size with 1 inch length. This does not require any alteration (like drilling and making the hole bigger).
slipped on a pipe insert to eliminate any play between the fitting and the pin. This also reduced the play between the original hole and the pin. Took some time to get the exact length.
Quite a perfect fit. no play. Now need to get some ties so i don't loose these.
AnikMankar...
Very nice! Where did you find the quick release pins and how much did they cost? I've had a difficult time finding them. Thanks!
[image: View Post]Knife, on 26 March 2010 - 07:42 AM, said:
AnikMankar...
Got them  ordered from Hongkong. He customized it as per my specs. The pins were cheap but got killed onthe shipping cost but i think it was worth it.
Quote
I'm with you Benny, 4 nuts on 2 wheels is a no go...unless someone fell down and needs a ride back.   :warranty:
Shouldn't you be on an airplane?
I forgot to tell you that you can feel free to use my home address as a shipping point if you wish while you are here.  I know you had talked about buying some motorcycle related stuff.
I did that for an acquaintance from Switzerland while he was here on a service call.  We got him an exhaust manifold for his jeep at a local junk yard.  (incredibly cheaper)  He ordered a bunch of clothing from Fox.  Fox would not accept his Swiss credit card so he gave me cash and I ordered on my credit card.  When the stuff finally arrived he had already left for home.  So.... I had to pack an exhaust manifold for a jeep Grand Cherokee and Fox skivvies (yes, black tighties) into a crate of tooling to be shipped back to his Swiss employer.   My boss was having a cow... he just knew we were going to get busted for some kind of export fraud.  More than once he said, "I ain't taking the fall for this."
But in your case, lets make sure that your stuff arrives before you pack for home.  I don't want to figure out the nighmare of shipping to India.
Hi Lee
I am leaving tonight - keep in mind we aer about 10+ hrs ahead. Thanks for the offer - if i order some more stuff from bandit - will ship it to you.
see ya
anik
AnikMankar...
:warranty: Hi Anik. Would you have a web address for where you got your QR pins for the seat cowl?
AnikMankar...
This guy Sissi is very nice and obliging. good luck
email: Sissi_ch@hkstools.com
Msn: sissi_ch@hotmail.com
Website:  www.hkstools.cn
www.hkstools.com
[image: View Post]Luvmyvfr, on 06 February 2010 - 05:28 PM, said:
That's what I was thinking, I took my grab bars off the very first day I got the bike....they are useless for a passenger to hold on to   :wheel:
Actually it depends on how savvy your passenger is. My wife uses them all the time. If we are going down a steep hill or if she knows that I'm going to slow quickly for a light she'll grab the handles. She is great on the bike, I sometimes wonder if she's still back there when I'm leaning through corners.
Final touches. I used a plastic coated cable.
Final cowl touches
AnikMankar...
:laughing6-hehe: Hi Anik. Would you have a web address for where you got your QR pins for the seat cowl?
www.hkstools.com
if more people are interested in this - he will drop the price - give my name as i have already spoken to him
regards
anik
Thanks Lee for the Cable swage tool now the this looks more professional. Got it right the first time.
Anyone knows where I can order a Rear Solo Seat Cover in RED color besides local dealers who wanted to charge for $190.00?  - Thanks, tom
they come up here about every other month and the same on e-bay.
End of thread · 36 posts recovered Wayback Machine snapshot 14 Oct 2012
