is our ignition the CDI type or the TCI type?
3 posts Started 27 Feb 2010 Last recovered post 28 Feb 2010 Wayback Machine snapshot 23 Jan 2011
im wanting to know, if our ignition setup is capacitive discharge, or transistor charged.
the yamaha fzr600 coils are of a common failing type, and they are commonly replaced with a coil from a ford escort, which does NOT have a primary resistance of 3 ohms, but more like less than 1 ohm. now, apparently this swap causes no problems, and the bike usually runs better, even.
now, were i to assume that we have the same setup on our bikes, would i be able to run 4 coils off of our box, with resistances of less than an ohm?
a little more info, the coils i wanna use are .8 ohm per cyl, the coil pack used on the fzr is something like .6 ohm. i can only assume that the coils it came with are 3 ohm saturation style coils, not cdi.
it doesnt seem to me like what i wanna do is going to work without some kind of cdi module and a stator that has a high voltage coil in it.
i REALLY dont want to run my stock coils.
End of thread · 3 posts recovered Wayback Machine snapshot 23 Jan 2011
