[image: View Post]jaimev34, on 25 March 2010 - 11:02 AM, said:
Do you guys have any tricks for marking the slider locations other than what's contained in the instruction manual?
There used to be a good how-to install thread w/photos on the forum, but I'm not sure if it still exists. Do a search and it may come up.
IIRC here's how I did it. You can drill either side first, but just for example I'll say drill the left side first.
-Remove both fairings
-Swap out coolant bottle and its contents (see below)
-Remove engine mount bar nuts
-Push engine mount bolt out the left side of bike using long drill bit (R&G instructions should say what size)
-Drill bit takes place of engine mount bolt, so leave a little sticking out
-Reinstall left fairing
-Attach drill to drill bit and carefully drill thru left fairing
-Remove drill from drill bit, leaving drill bit sitting in engine mount hole
-Remove left fairing
-Push drill bit thru engine mount hole using engine mount bolt
-Push engine mount bolt out the right side of bike using drill bit, again leaving tip exposed
-Attach right fairing
-Attach drill to drill bit and carefully drill thru right fairing
-Remove right fairing
-Push drill bit out right side of bike using R&G slider mount bolt, leaving tip showing on right side
-Attach right fairing and use Dremel to slowly expand hole, checking with silver cylindrical spacer for fit as you go
-When right fairing is good, push slider mount bolt further right, leaving tip exposed on left side of bike
-Attach left fairing and use Dremel to slowly expand hole, again using the silver space to check fit as you go
-When left fairing is good, push slider mount bar to left to center it
A few points to remember:
-Use goggles or safety glasses and a dust mask. You don't want the plastic dust from your fairings in your eyes or nose/mouth.
-There will be a decent amount of discarded plastic, so make sure to clean off your fairing inside and out, including the shavings that will drop down from the hole inside your fairings.
-Now is a good time to do a coolant flush since you're replacing the coolant bottle anyway. It's also a good time to do an oil and filter change since the left fairing will be off the bike.
-Go slow if necessary! Neatness counts. No points for how fast you can do this install.
-The mount bolt will be tightly fit. I used a rubber mallet to move it back and forth to prevent damaging the ends and threads.
-When attaching the locking nuts for the sliders, lightly grease the threads. I use a little white lithium grease every time I reinstall the sliders.
Everyone - Please feel free to correct or add to my instructions above.
