[image: View Post]rcbaker, on 17 May 2010 - 11:47 AM, said:
[image: View Post]PolarBear, on 17 May 2010 - 12:48 AM, said:
[image: View Post]rcbaker, on 17 May 2010 - 12:43 AM, said:
[image: View Post]PolarBear, on 17 May 2010 - 12:06 AM, said:
[image: View Post]rcbaker, on 16 May 2010 - 11:34 PM, said:
I have the same Signal Dynamics voltmeter on my 5th Gen. Mounted it on the top left of the plastic cowl that surrounds the instrument panel (just under the windshield). I had the front cowl off so it seemed like a good opportunity to install one. It works great and is very visible but not so much as to be a distraction. I had a voltmeter on my 4th Gen mounted just in front of ignition key and it was OK, but only useful is one actually looked at it. The Signal Dynamics "idiot light" is in my view a much better solution. If the voltage drops (or spikes) you know about it right away. The voltage processing unit was mounted under the horizontal gray cowl to the left of the forks using the two sided adhesive tape supplied with the unit. I am really pleased with it.
Aha! This will look suspiciously like mine, but with the 6th gen version, of course. A good way to protect it from rain and crap, right?
C
Yep, stays completely out of the weather. The kit includes a little plastic ferrule that you insert into the 1/4 inch hole you've drilled (from the outside), then you push the LED in from the back. Be careful at this stage - it take quite a lot of push to get the LED to clip in. I managed it by using needle nose pliers to clamp the ferrule against the plastic cowl while pushing really hard (but carefully!) on the LED assembly until it finally seated. Enjoy!
Hey,
All right, since this requires some finesse, I'll try and pick a day when I'm patient and in a good mood to plug it in. BTW, I isn't want to ask since it seems to basic, but how did you hook it up? Directly up to the battery (seems easier to me if it is doable) or did you tap into the rear light wires? Not too sure what te kit comes with yet, I ordered from a local business here and they didn't have any on display.
Thanks,
C
I have Tightwad's VFRNess on my bike (if you don't have one yet - get one), as well as his accessory fuse panel kit mounted under the seat. Pic is attached. Proper grounding is often an issue on these bikes so I ran a ground cable directly from the battery to a terminal I created under the seat by drilling a hole through one of the plastic U-Bolt brackets build into the fender. Put a bolt through it and voila, a second ground terminal direct to battery! As for the wiring, I ran a switched line from the fuse box and a dedicated ground up the left side of the frame to the front of the bike where I connected it to a Powerlet outlet in the steering stem. I tapped into these lines just behind the instrument panel to get the voltage and ground for the voltmeter. Link to Tightwad's site is
Wire My Bike. High quality stuff at a very reasonable price.
Hey,
Just got the vfrness myself with the accessory plug. I'm in the process of installing it--still not sure how to route the harness, but your info will help. I've pmed Josh too for some more pics.
C
