So some previous owner (noob) installed a ProGrip for the throttle. Problem is they seated it out about 1/2" too far. It rubs on the bar ends, even with a million washers installed. Quite annoying.
Is the only option cutting it off and installing new grip?
I have never needed more than my air compressor. shoot the air under the end of the grip all the way around, and it should come off.
To put it back on you can use grip glue. I always just use a spray bottle with a mix of soap and watter. Makes it easy to slide on, and has never moved. (Yes same method for my track bike with no issues - if I pull the grips so hard they move I am probably doing something wrong anyways:-)
I've never used glue on my motorcycle grips and they've never come loose. On my bicycle grips I've used some of my wife's hairspray(it was handy). Slippery when wet but sticks when dry. I like to use Electrical contact cleaner or rubbing alcohol to remove the grips.
Funny, the guys at the Ducati shop use clear spray paint as well.
I have used hairspray in the past for bicycle grips as well. I switched to the soap method as the soap seemed to hold up to the sweat better over time than the hairspray.
For getting grips on, I tend to use denatured alcohol (methylated spirits). It's a liquid, so the grips slip on over it, and then because it's alcohol, it evaporates!
My race bike has lock wires on its grips, but that's a bit of overkill for road work.
A water based lubricant that has multi purposes :lobby: and puts 'more slip on your grip' and when the party's over, dries up like nothing ever happened...... :sad:
To remove grips: Shove the little red tube from the WD40 under the grip, spritz, remove and repeat at 120 degree intervals. A little manipulation and the grip is off.
To install: Thoroughly clean the WD40 off the grip and bar. I like brake cleaner. When done, wet the inside of the grip with cleaner, slide into place and adjust. Wait for cleaner to evaporate. Grips won't be coming off.
Glenn
End of thread · 10 posts recoveredWayback Machine snapshot 16 Jun 2011
