InterFester
I had done a few sketches of what should fit and merge correctly. It's important to step the diameter up correctly and not go too big anywhere. Headpipe diameter and length before the merge is the most important. I'd use the OE headpipes, or most of them, and go from there. Make them all the same length before they merge.
Rough headpipe estimates for an engine that redlines at 10,500rpm is 20" to 24" long before merge. Depending on how much of the OE headpipe you can use, step up only one pipe size, like 1" to 1 1/8", until they merge.
A proper merge is 30 degrees combined angle. Meaning each pipe is at a 15 degree angle from the centerline. This can be done with a chopsaw using a wooden jig to hold the pipe correctly.
The shape I came up with for a 4-2-1 was an "H". The fronts merge with the rears as they all bend towards the center. Then those two merge and bend towards the rear in the middle of the "H" cross bar so to speak.
What is the ID or OD of the original headpipes?
Right. armed with a tape measure, my camera and the grinder, I've had a bit more of a look at this.
The original pipes are 30mm ID, and the front pipes are ~450mm (17") long. Using the formula for the resonant frequency of a single organ pipe (F = Speed of Sound / (Length + 0.3*Diameter)) gives ~11,000 RPM.
The rear pipes themselves are much shorter, but the extra length is hidden in the collector. Like this:-
[image: DSCF3986.jpg]
[image: DSCF3985.jpg]
So doing a 4-1 with those lengths, using a merge collector is going to be difficult.
So I've decided to try to use the exhaust to help boost the mid-range, by using a 4-2-1. This may sacrifice some top end power but should help general road manners. The RC30 and RC45 are both V4 engines with 360ª cranks, and they both use 4-2-1 systems with front pipes into one side of the "2" and both rear pipes into the other. It doesn't seem to hurt them!
I don't know if the organ-pipe modelling methods work for this type of thing, it definitely does for inlets. But here goes:-
Using the organ pipe-type method for the resonant frequency of a pipe, and using 7700 RPM (128Hz - pipe resonating twice per cycle) and 11000 RPM (183Hz), I've got 460mm and 659mm for the lengths of the primaries and the primaries + the secondaries respectively.
If the length of the tailpipe (which I've assumed includes the straight-through silencer I have) is 659mm + 75mm, as recommended by A. Graham Bell in his book "4-Stroke Performance Tuning" then the resonant frequency of the entire system should be at 3600RPM. I've assumed that primaries and secondaries are both 30mm ID, and the pipe linking to the can is 50mm.
Does anyone agree/disagree?
