My next (and maybe last) big mod for my 6th gen. will be an aftermarket exhaust system. Trying to decide between the LV SBK and Two Bros M2 VALE systems. Definitely want carbon fiber, as I bungee stuff down to my rear seat often and sometimes the bungees rest on the stock exhaust cans' heat shields, and the bungees won't (or shouldn't anyway) burn on the CF cans.
I like the looks and sounds of both systems. I actually prefer the looks of the VALE but like that both cans are functional on the SBK. I also worry a little about the absence of a heel guard/heat shield on the VALE, tho I'm sure I could get one mocked up for it if necessary.
The big issue is that I have the OEM hardbag brackets mounted on my bike, which stay on there all the time. I believe the SBK is compatible with the hardbag mounts but have not been able to find out whether the VALE is, too. I searched all 12 pages of threads in this section of VFRD for help but never found the answer and could not find a single photo of a VALE/hardbag brackets combo.
Questions:
1. Is the VALE system compatible with the OEM hardbag brackets?
2. If you have the VALE system and hardbag mounts, can you please post a pic of your set-up?
3. The VALE system Has the absence of an up-pipe heel guard ever been an issue?
Thanks in advance for your help!
Questions:
