OK, at some point I promised to do a write up of the conversion of my '91 so here goes. The bike is far from completed but it's driveable and I've logged some 3000km on it this summer. Next winter the work continues.
Here's an early pic from the spring of 2009 when I started with VTR1000F front end conversion along with CBR918RR brakes.
[image: gallery_16614_5090_149953.jpg]
In the early stages
At this point I also went through the internals of the fork after having read about the poor suspension quality of the VTR. The springs are 0.866kg/mm (8,5N/mm) Öhlins straight rate springs for the VTR.
The modified the shim stacks are the following:
Compression stack:
17 x 0.4
Showa 3 port surface dressed - bleed notches removed, with 1mm bleed
17 x 0.10
16 x 0.10 (2)
15 x 0.15
14 x 0.10
C 8.5 x 0.20
11.4 x 0.4
Rebound stack:
17 x 0.4
17 x 0.10 (8)
16 x 0.10 (3)
15 x 0.15
14 x 0.15
C 8.5 x 0.20
11.4 x 0.4
12.5 x 2.6
After some testing I settled on 120mm oil height IIRC which seems to be working great. Here's a little pic of the work:
[image: gallery_16614_5090_909431.jpg]
And one with the finished front end:
[image: gallery_16614_5090_676162.jpg]
The bike was ridden like this almost the whole summer of 2009. And while the front end felt great the rear suspension was not up to par and so I decided to contact Jamie D for a CBR929 rear shock. That was a great decision. I could feel the tremendeous improvement in ride quality and stability right from the start.
Then last fall I had read enough about FotoMoto's CBR600RR and other's conversions to have a go at it myself. I'll let the pics tell the story:
[image: gallery_16614_5090_217613.jpg]
Fitting the CBR fairing stay.
[image: gallery_16614_5090_151122.jpg]
Test fitting the front fairings. Also note the Coerce fork brace made for the VTR. Fit's perfectly.
[image: gallery_16614_5090_545730.jpg]
New chinese front rotors from Ebay. Currently I ridden 3000km with these and no complaints what so ever.
[image: gallery_16614_5090_402129.jpg]
The Koso gauges installed. I had the same trouble FotoMoto had with bouncing tach needle above 6000rpm and no trick I tried cured it while using the original tach wire for gauges. Switching to the coil sensor wire supplied with the Koso remedied this. It's connected in between the the coil low voltage terminal and ECU and the gauge is set up for a 2 stroke 1 cyl engine and "Hi act" IIRC. Can check this if anyone needs the info. The temp sensor is the one supplied with the gauges. With this set up the gauges work perfectly.
[image: gallery_16614_5090_340530.jpg]
Koso RX1N gauges All wired in and working but no temp yet.
More test fitting, now with the windshield installed.
[image: gallery_16614_5090_579174.jpg]
Windshield installed
Bracket for the fairing made out of aluminium sheet to use the original speed fasteners.
[image: gallery_16614_5090_826363.jpg]
Wiring in the electrical speed sensor from a 2001 VFR800. Using the Koso's 5V supply for speed sensor and splicing the VFR800 unit into the gauges original wire worked perfectly. Currently my speedo is set up with GPS within 1% accuracy.
[image: gallery_16614_5090_261817.jpg]
The fuel gauge also works nice. It's even accurate where the original was not quite. :laughing6-hehe:
[image: gallery_16614_5090_652836.jpg]
Also installed Factory Pro shift kit (the kit I got must have been made on Monday since I had to reassemble it correctly), a lighter battery, an aluminium rear sprocket with 15-45 gearing, VTR1000F clipons and more.
[image: gallery_16614_5090_215151.jpg]
Current state of things Trial fitting of the CBR600RR upper. Oil change in process and Factory Pro shift kit installed. Still lots to be done.
Also installed LED signal mirrors from Ebay.
[image: gallery_16614_5090_796807.jpg]
It's a driver... ...and also very incomplete.
The VTR clipons are visible in this pic. Also the brake master is a radial unit from a 06 GSX-R1000 but I could get it blead properly so switched back to the CBR918RR master that works great. Probably the problems with the bleeding are caused by me using original VFR length braided lines where I would have needed shorter ones with 90deg ends for the Suzuki master.
[image: gallery_16614_5090_856041.jpg]
The cockpit as it's now.
After the last pic I've installed VTR1000F clutch master and a Delkevic titanium stubby muffler (only 1,25kgs). I've calculated the bike has lost some 12-15kgs (26-33lbs) in total and will lose more during next winter. Made some measurements using the Koso's performance test and got a couple of 4,2s 0-100kph runs so she runs strong (the needles shimmed and a BMC filter installed).
Coming up is a jet kit with larger intake snorkel, an aluminium rear subframe with a '04 GSX-R600 tail fairing and LED lights and either a high mount of left exit exhaust using the Delkevic can without the huge collector box and of course a paint job (original color). Will post pics when get them things done.
EDIT: Also changed to GP-shifting using modified gear linkage from an old CBR600F.
Edited August 25, 2010 by FinnRC36
