speedometer problems VFR 750 CBR 1000RR 96
4 posts Started 26 Sep 2010 Last recovered post 26 Sep 2010 Wayback Machine snapshot 16 Jun 2011
I have a VFR 750 96 to the replacement of the odometer by the CBR 1000RR and good what is the cable because there are many colors that match looking at both charts, after being a late tying cables and turning half crazy with the two diagrams temperature sensor that brings the cable is 1 VFR and CBR are 3 and 120 degrees clear me na mark after starting the bike and wanted to know if you know how to solve the problem, I'll have to put that aside for a theme SH velocity meter, and idk if I'll have some trouble.
Have if someone can help me
Greetings
Hola Espana :fing02:
See post #45 in this thread for wiring information:
http://www.vfrdiscus...er-texas-style/
I used a Koso water temperature sensor but I think Travis (tdchonda1) found another Honda sensor that will also work (cbr900rr????). You will also need a speedohealer version 4.0 or higher to correct the cbr1000rr speedometer.
Thanks, I thought you had installed on the VFR 750 cbr 100rr speedometer instead of rx1 koso, gotta have investigated whether the problem solved
No, I do have a CBR1000RR unit. I tried the KOSO first but the tachometer didn't work properly on it. It came with an additional temperature sensor (for oil) that I kept and used along with the cbr gauges. Please check the whole thread (sorry it's long) but post #45 has the wiring instructions for VFR to CBR gauge conversion.
End of thread · 4 posts recovered Wayback Machine snapshot 16 Jun 2011
