Yep East London, not to far from the new Olympic Park.
for a new Rec/Rec use David Silver spares, easy to find via google and buy the uprated one. About £99 at the mo' ISTR.
This may help, I've copied it from another site I'm a member of
Symptoms.
1. The FI warning light glows dimly.
2. The FI warning light can go brighter and dimmer at random.
3. The FI warning light can act in sympathy with the indicators and brake lights.
4. The FI warning light can react to switching between dip and main beam.
5. The engine misfires, splutters and even cuts out when the FI warning light illuminates.
6. The FI warning light doesn't display any fault code.
The above symptoms can tend to get worse after you've been riding for a while.
Possible Cause.
On this model of VFR, many components earth wires all come together into an earth block before they then connect to an earth point on the frame. [image: huh.gif] For example, there are 12 wires coming into the block from different components/systems and only 2 wires going out to the main earth point on the frame. If there's any resistance built up in this earth block, the components will try and earth back through another component - hence the FI warning light glowing. The symptoms can get worse the longer you ride for because the point of high resistance in the earth block heats up and the resistance increases. [image: angry.gif]
Things to check.
The easiest option is, when the FI warning light is glowing, is to turn the lights off. This is because the lights are trying to earth through the FI ECM. If the FI warning light stops glowing, then your culprit is most probably the earth block.
Location of the Earth Block.
The earth block in question is located on the LH side of the bike, just forward of the Voltage Regulator/Rectifier, you'll find it taped into the loom. When you remove the tape you'll find a red/orange plastic block about 30 - 40 mm square.
The Repair/Fix.
The repair or fix can go one of two ways, it'll either be easy or a real pig. My luck had it that it was the latter. [image: banghead.gif]
1. Ease the cap off the earth block or open the lid to the cap. Inside this you'll see a series of prongs - one set of prongs link six connections together, the other set link eight connections together.
2. If the prongs and the connector block look clean, then just spray contact cleaner into it, reassemble it and give it a try.
If this fixes it, then you've had the easy fix. [image: thumbsup.gif]
If the above hasn't fixed it, [image: huh.gif] then read on - all is not lost.
1. If you open the lid of the earth block cap, you'll clearly see the backs of the links. The FI, tail lights, brake lights and indicators all earth through the link with 8 prongs.
2. Remove the links from inside the cap and put them straight into the earth block, just make sure you get the right link in the right place. Then close the cap lid and refit the cap over the top of the links. This'll push the links further into the earth block and may give a better contact. Now give it another try. [image: scratchchin.gif]
If this fixes it, then you're doing alright. [image: smiley.gif]
If that hasn't fixed it, then life gets fun.
1. Remove the cap to the earth block.
2. With a multimeter, do a resistance check from FI ECM connection B1 back to the earth block. This'll show you which wire earths the FI ECM.
3. Cut the wire you've identified where it goes into the earth block.
4. Cut a suitable length of fresh wire that'll reach from the cut end of the FI ECM's earth wire to the bikes wiring loom's main earth point on RH side of the frame (roughly where you're right knee/leg goes).
5. Solder one end of the new wire onto the FI ECM's earth wire and weatherproof the join. Then crimp a ring tongue connector to the other end.
6. Remove the earth point bolt and add the new FI ECM's extended earth to the earth connections already there and refit the bolt. This gives the FI ECM it's own dedicated earth so nothing will be trying to earth back through it. [image: applause.gif]
At this point you have a choice.
One option is refit the prongs and cap to the earth block, but the problem still remains, it just won't affect the FI warning light anymore.
The other, and permanent fix option, is to cut the other 7 wires to the eight pronged link (shown by red arrow below) and solder them together (shown by yellow arrow below) - that's the route I took in the end. Some silicone sealant over the resulting blob of solder keeps the weather at bay.
HTH.
Thanks to John (aka Odie) for the above info.
