hello , my name is Philippe , 52 years ago , i have VF 1000 R since 10 years
I found listed since November, but expected to have modified my end before posting
translation is from google translate, it's not terrible, but my English is too bad ,so be indulgent
for quite some time, I had the idea of changing my wheels on grandma to be able to adapt to rubber tires modern, I know, purists will still be pain but me, as long as I keep in mind VF, that's enough
Note: I am able to manage everything back home if appropriate.
home
Front: 120/80/16, there are almost as diagonal (2.5 inch rim)
Rear: 140/80/17, not much choice and 150/70/17, but the tire of choice is a little pinched (3.5 inch rim)
-Over from the TLR with R1 radial brakes and 19-radial Nissin 2 piston and TM 14 of Grandma, it does not too much, so I bought a PR of 17.5 Nissin radial ZX 10 R and will take the opportunity to install (I did not, back to my MC SVN, prob because the MC's ZX) I thought I could change the brackets in favor of more modern (4 pistons) but it has not seem playable with the fork and the TRAC system of shit
After several research and especially read the topics on the site VFRD (see below)
http://www.vf1000r.f...hp?topic=5171.0
I decide to go ahead and enjoy the off season to make my annual review and change my rims
I also enjoy to change my rear shock profile of a VFR 800 of 2003 occasions. After installation, I must say that the work being static amorto the saddle, suspension and slightly firmer than the original but much more smooth, short I am satisfied, I will see use on the road but a priori. ... happy.
I am especially inspired this topic where we see what the end result can give
http://www.vfrdiscus...f1000r-rebuild/
So, I chose to wear on rims CBR 600 F2 (91-95)
VA: 3.5 inches: classic tire: 120/70/17, you can find anything
AR: 4.5 inches: 160/60/17 tire, and ...
I saw that some took the CBR F 3 (5-inch rear wheel), and even at 900 CBR, see url above topic (rim 5.5) but the 180 goes too just to my liking in the soundtrack of origin
Changes required:
Building on this:
http://www.daugherty.../v4section.html # wheelswap
Front wheel: the axis of the CBR is 20 mm, that of the VF 1000 R 15 mm, more because of the dismantling "racing" not at all conventional obligation to keep the axis of VF as the centering and wheel positioning are packaged. washer drive VF counter to change the wheel to enter the CBR
Bearing change (fortunately, the diameters of the outer cages are the same on both wheels)
Machining of making a reduced speed of 7 mm (3.5 inch rim, it takes more space)
Machining a spacer of 10 mm for the right side for the nut-bearing does not fit into the joint
Machining of 5 mm from the nut-bearing (I could have put less in fact) but it allows me to more easily control the centering of the wheel
The only change is irreversible I authorize, which oblige me to have a brace on the right in if I return to the original wheel.
Rear wheel: VF axes and CBR are the same diameter, so I put the CBR
Probs:
The ring gear is not the same thing, and I can keep the support bracket or the back of VF (vented disc) which amends and creating a tab for mounting bracket
Moreover, must center the wheel and keep the alignment of the chain.
Changes bearings (buying secondhand wheels (history?) And epoxy under the warrant)
Machining of a spacer (left) of 14 mm to 12.5 mm reduced
Machining a spacer (right) 19 mm
Creating a tab for supporting bracket
Me 3 choices are offered to the views of my research
I chose it because easy to do (the soundtrack is hollow) and aesthetic
here are some of my tofs Change shock
I inspire mods sold on this site
http://www.daugherty...ifiedshock.html
shock of the VFR is 315 mm, that of the VF of 400 mm, or 2 feet to accommodate
from what I read, no need to change the setting of the spring, which proves true, static
work:
machining of parts was done by a colleague and chest by my son who has a small tower and a mill, I'm just the caliper support bracket.
epoxy coated white in Bobigny (sanding paint +)
Changes bearings (watch those AV are 1 mm wide (to be taken into account for the spacers) by the father of my son.
Acknowledgements:
Thank you to Thomas, Dominica, Samuel for machining operations
Thank you to jmjvtt21, keesb1, vfrcapn for info and tofs
To thank you for taking meter and calipers valou45
Thank you to the B1200 to approach with epoxy Bobigy
Cost: boncoin and pieces on the ebay (price including shipping fees or travel)
- CBR 600 wheels complete (on + wheels + tires (Supercorsa mid-wear)): 150 �
- rear caliper hand + CBR 600 platelets in good condition: 20 �
- 2 bearings AV: 6302: 15/42/13: 12 �
- 2 bearings AR: 6204: 20/47/14: 12 �
- Right front wheel attached: 22/42/7: 7 �
- Left front wheel attached: 45/55/5: 8 �
- Right rear wheel attached: 34/50/6: 7 �
- Washer drive counter VF: 6 �
- Epoxy wheels: 80 �
- Socket meter (to put the same): 15 �
- Rear brake hose: 20 �
- Rear sprocket in 530, 43 dts: 28 � (that was the cbr 520 (track)
- Material for spacers and various: gratos home
total of 365 � for wheels
- Amorto VFR 800 2003 (23 000 terminals): 63 � (leboncoin)
- PR of 17.5 Nissin: 100 �
- This, just add the various consumables for my annual review and some things to change.
- Chgt FITRE gasoline
- Chgt oil filte
- Clean air FITRE (KN)
- Oil change
- Chgt front and rear brake fluid
- Cleaning and painting calipers front and rear
- Cleaning candles
- Valve clearance set
- Maintenance Kit starter set (brushes, bearings, seals)
- Ldr changed
- Battery door removed and repainted
- Lubrication various points of articulation
- Chgt intake pipes (new)
- Chgt seals leaking tanks carbs + carbs supply pipe inter
So that the beautiful output of the workshop for some tofs before taking up his winter quarters
[video outdoor
Mamie there 2 years ago
2 years ago
home
Changes required:
Building on this:
Probs:
work:
Acknowledgements:
- Chgt oil filte
- Oil change
- Cleaning candles
- Ldr changed
[video outdoor
2 years ago
