[image: View Post]Dutchy, on 17 February 2011 - 12:24 PM, said:
[image: View Post]vfrdoc, on 17 February 2011 - 08:28 AM, said:
Just an update.......all I got time for :laughing6-hehe:
I have the fiberglass almost done, just need to do the "pretty" work now. Only problem .......... life. :mellow: Why is it when you get half way through a project SOMETHING always happens and you have to put it on the back shelf until the SOMETHING is done? :blush:
On the bright side.....
At least you have a back shelf to put the thing on.... :laughing6-hehe
and....... :worthlesswithoutpics: even the rough ones!
OK Dutchy, you wanted pics so here they are.
Make the curve parts by soaking the wood (balsa) in water overnight then wrap the wood around a dow or something that has about the same size curve you want and let dry overnight. Just remember the dow you use make it about 20% smaller than the final curve. The wood will tend to try and straighten out once you take it off the dow.
[image: Attached Image: 023.JPG]
The next pics are the rough flat and some of the curve pieces. I used gel super glue to bond the planks and curve pieces on, make sure to put a papertowel down some of the glue might drip to the workbench and glue your project to the bench :pissed: With the papertowel you just have to sand off.
[image: Attached Image: 013.JPG]
[image: Attached Image: 018.JPG]
The next part is a little tricky, and was done using the "shapper" it is the blue strip looking thing in the middle. Not sure what it is really called but I got it at Micheals arts and crafts store. The thing is really cool, it bends to the shape you need so you can match it to your project. Takes out a lot of the guess work. :fing02:
[image: Attached Image: 014.JPG]
The fiberglass part on the back was made using the "shapper" this is the part that goes under the tail light. I did this by applying resin to each corner and letting it dry, then applied a thin layer of resin to the rest of the fiberglass and as it is drying matched the curve of the tail light using the shapper. Careful not to touch the tool to the resin, just get it close enough to make sure you got the right bend. It doesn't have to be perfect just close.
[image: Attached Image: 027.JPG]
This is were I am right now, what I call pretty work is the filling and sanding to get the finished part before paint. What you are looking at is really just the "skeleton" :biggrin:
Maybe in the next couple of weeks I can get back to it and finish it :blush:
