[image: View Post]YoshiHNS, on 12 March 2011 - 10:38 AM, said:
[image: View Post]2FAST4U, on 12 March 2011 - 09:17 AM, said:
I don't know much about your bike but on a 6th gen. VFR like mine, the following are common methods of reducing weight:
Everything stated above will shave about 40 lbs. off the bike. That's about as far as you can go without spending serious cash.
You sure about that? 40 lbs? Seems a bit optomistic there.
There's not much you can do that's simple to reduce weight on an RC30 that I know of.
Although these are estimates, they should be fairly close
1) Installing aftermarket exhaust cans - 11 lbs.
2) De-linking the brakes - 6 lbs.
3) Getting a lithium battery - 7 lbs.
4) Removing the passenger footpeg assemblies - 4 lbs.
5) Removing the passenger grab rails - 2 lbs.
6) Removing the center stand - 3 lbs.
7) Installing a fender eliminator kit - 2 lbs.
8) Removing the tool kit. - 3 lbs.
This actually comes out to 38 lbs.
Removing the chain guard (like I did) and getting an aluminum rear sprocket - 2 lbs.
Edit:
Losing 40 lbs. and with a setup including a Power Commander, dyno-tuning, a high-flow air filter, catless headers, and non-quiet baffles removed from the cans, you could conceivably knock .2-.3 seconds off your 1/4 mile e.t. The best e.t. I've seen (for a 6th gen. VFR) was an 11.2 @ 120 mph. With this setup, you're now talking 11 seconds flat or a very high 10. If you got the big bore kit, you'd definitely be in the high 10's.
