I am trying to remove the rear axle but I can't get it to budge. The sprocket carrier came off easy, next was the collar that only took a light tapping to loosen up. Third was the backplate of the cush drive, it came off using a puller but it took more effort than expected/hoped.
[image: 51734885.jpg]
Only thing remaining is the axle and and unfortunately the puller is not large enough to use it on the axle too. I gave the axle some smacks with a hammer but absolutely no movement whatsoever. I didn't find it in the service manual or on the parts fiche but just to make sure, there isn't some circlip keeping the axle from being removed from the bearing holder, is there?
[image: 78974954.png]
