My modified VFR
50 posts Started 1 May 2011 Last recovered post 5 Feb 2014 Wayback Machine snapshot 3 Apr 2020
[image: post-22571-0-03747200-1304262276_thumb.j]
I have visited this forum on lots of occasions, but never got around to registering.
After looking at quite a few of the Frankenviffer threads i thought i would show my bike.
Its quite a collection of honda parts you will see.
Due to my work, its taken me alot longer than i would have liked to get it to its current build level.
Anyway its basically a VFR750 frame and engine of 1996 era with CBR1000RR forks, cbr900rrx swinging arm, VTR1000 wheels and cbr600rr seat unit plus loads of one off parts.
[image: post-22571-0-76528100-1304262334_thumb.j]
Sorry about the pic sizes.
Heres some slightly smaller ones.
[image: post-22571-0-01386000-1304262508_thumb.j]
[image: post-22571-0-93540500-1304262533_thumb.j]
LOOKS GREAT !!!!!!!!!!!!!!!!!!!!! Your almost there .
Welcone to VFRD from across the Norht Sea
A super looking Über-Frankenviffer :fing02:
Thanks for sharing, looking Good! :fing02:
Twin rear is a cool add! :beer:
Looks really great. :fing02: I like the USD fork setup along with the rearsets.
information on how you got that swingarm on that bike would be VERY VERY VERY appreciated. please share it with us!
flyguyeddy
and where did that set of gauges come from? did u get them off of ebay from china? because it does NOT look like a koso setup, no shift light
OK, I can get behind the swingarm, etc, but I have a concern about those oil lines. They stick out very far. Maybe a 90 fitting and run them near the radiator or something?
And maybe some mirrors and turn signals? Or combined?
I'm not really into the naked look, but nice clean job anyway.
Larry
VFRrider
Edited May 1, 2011 by vfrrider
1st off mate, Welcome.
Bloody-L that's a sweet ride, love what you did to it.
flyguyeddy
The swinging arm fits straight into the frame once 12mm has been trimmed from the righthand inside of the frame. I used cbr900rrx linkage plates and dogbones and they all bolted on with no mods.
Really quite a straightforward convertion. the hard part is getting the exhaust routed through the swinging arm beside the shocker.
vfrrider
Larry
VFRrider
Hi Larry, thanks for the concern about the oil cooler lines. i have got a bracket to fit to the righthand oil line, but it wasnt fitted in the photos as i'm still finishing bits and pieces off.
flyguyeddy
flyguyeddy
The clocks are from Dan moto in china, but are on the to get changed list as they wont work with the VFR loom. i have another set of clocks on the way that are koso ones but not the same style.......hopefully these will resolve the issues i have at the minute.
robwalmsley
welcome ,nice machine :fing02:
Thank you kind sir
vfr750gaz
flyguyeddy
do u have any pictures of this modification? i am concerned about the strength of the frame where the adjuster goes into it.
does this offset the swingarm enough that u have to change around the rear wheel spacers?
flyguyeddy
vfr750gaz
flyguyeddy
Hi,
Sorry i dont have any pics of the modification. Theres no way the strength of the frame is compromised as the threaded adjuster has more than enough meat on it to tolerate having the 12mm removed from it. I have an early fireblade and its adjuster is much narrower as standard.
The wheel fits straight in using the standard wheel spacers etc and runs central in the frame without mods.
Very nice, and ditto on the oil lines. Need to tuck those away somehow. Other than that, great show!
vfr750gaz
flyguyeddy
vfr750gaz
flyguyeddy
Hi,
did u use the 900rr swingarm pivot bolt and frame adjuster? how did you remove the 12mm from the frame and keep it perpendicular to the pivot shaft?
can you take some closer pictures of the exhaust and shock area please?
flyguyeddy
vfr750gaz
flyguyeddy
vfr750gaz
flyguyeddy
Hi,
You can use the standard pivot bolt, but the adjuster will need shortened to suit the mod. i hacksawed 10mm from the inside of the frame and used a facing tool a madrel that was a snug fit in the pivot bolt holes to clean the last 2mm off.
As for pics of the exhaust and shock area.....i will try and take some, but it wont help you carry out the work to be honest as the rear cylinders headers are entirely dependant on the exhaust your using.
vfr750gaz
flyguyeddy
vfr750gaz
flyguyeddy
vfr750gaz
flyguyeddy
Hi,
U didnt have to move the shock pivot on the swingarm at all?
flyguyeddy
vfr750gaz
flyguyeddy
vfr750gaz
flyguyeddy
vfr750gaz
flyguyeddy
Hi,
The shock pivot point on the swinging arm matches up perfectly. Thats why the vfr swinging arm into a fireblade is so easy (all offsets and distances are the same).
Nice work gaz, looks great! I like it a lot, except the headlights... they're a bit high.
What brand of front rotors are you running?
& is there any chance you can post a nice sound clip for us? :musik20:
Im personally, absolutely in love with this bike! Couldnt think of a better way to make a custom 4th gen! (Aside from a vfr800 engine:)
SEBSPEED
I guess the headlight height is down to personal preference and i like them where they are.
The front rotors are PFM supersport discs that were originally intended to go on a CBR900RRX (310mm diameter).............I had alot of work to do in order to get these to fit both the wheel and the forks.
The PCD for mounts were correct, but the centre hole was slightly too big and then i had to space them out by 4mm per side to bring them into the centre of the radial calipers.......all sorted now though.
I could do a video of the bike running, but unless i can borrow an expensive mic then it wont do the bike justice..............but i will say it sounds like no VFR i have ever heard before!
flyguyeddy
My next project after i have finished this is a special based around a VFR800 engine......custom frame and super charge the engine.
The only problem is with the VFR750 motor is it doesnt give up extra horse power easily and without great expense, but i cant complain as the bike i'm building now weighs next to nothing so its power to weight is greatly improved over standard.
I'll have to weigh the bike, but it feels like a scooter to push around and thats with a full tank of fuel.
Looks good!!! What type of rear sets are those, and where did you get them?
douglasthecook
There Harris rearsets designed to fit a CBR900RRX......bolt straight on with only a spacer required for the gearshift shaft fitting.
Nice looking ride. If it were mine, I might consider using the Laminova oil cooler used with the A&A supercharger kit to loose the oil "radiator". I think it would look pretty sweet with either the 599 headlight assembly or a naked stacked projector setup off a Duc 999, but that is just my preference too. Some really nice craftsmanship, especially that exhaust.
Very nice work indeed! You've done some interesting things that I haven't seen done to 4th Gens before.
Swapping the swingarm is a great idea for performance as the SSS weighs twice what a conventional arm does. Normally I'd miss the look that the SSS gives a VFR, but you've balanced it out perfectly with the dual exhaust, very clever. The VTR wheel is also lighter, so your unsprung weight at each end is greatly reduced - excellent for handling. Are you still running a 530 chain, or smaller?
And why CBR900/929 shocks work so well in VFRs, the linkages allow the shock to work perfectly within its design spec. Amazing how Honda parts interchange.
You have a similar side profile to mine (which has a 2002 R6 tail). The 600-class seats line up nicely to the back of the VFR tank, because even though it is such a large tank it narrows at the rear courtesy of the narrow V4 layout.
[image: 4166661450_0b615dc813_b.jpg]
The Phantom
The bike has the shocker in it from a cbr929 and i converted the chain to 525 to save a little weight and i have also used lots and lots of titanium fasteners.
what subframe are u using under that tail? is it a custom tubular setup or some factory piece? the 600rr's have a cast subframe...
Looks great!! Welcome to the Forums!
hoping for some more pictures of this beast...
very nice work i actually just did an 09 cbr 600 tail swap to my 94.
[image: gallery_20102_5910_31923.jpg]
IMG 20110512 180327
THAT LOOKS GOOD !!!!!!!!!!!!!!!!!!
Switchblade
there needs to be more pictures of this.
So far the frame modifications have been easy peasy. I swapped the 4th gen adjuster for the third, which is alot shorter and seems to be perfect for this. Threads right in. I did notice that the suspension linkage doesnt exactly line up, but its pretty damn close.
how hard was it to fit the cbr600rr tail subframe? Would like to know cause i was thinking about doing it as my next project.
Thank in advance
vfr750gaz
Member Since 01 May 2011
Last Active May 21 2011 06:46 AM
I don't think you'll be hearing from Mr. Gaz since he only hung around for 20 days last year. Too bad really. Nice bike.
Is that a custom exhaust?
Sure looks nice......
vfr750gaz
[image: attachicon.gif]SL371113 (Large).JPG
[image: attachicon.gif]SL371114 (Large).JPG
Holy !!!Floored. Just found this one...
Custom exhaust that's never been hot ....
[image: post-23976-0-58834700-1391548455.jpg]
Bike is back, but different owner.
Feels like cheating by posting the bike here,(since I didn't[image: post-23976-0-84584800-1391549053.jpg] built it) but thought maybe people are still interested in it.
cheers,
Peter
ps also a picture of my own special still in progress
I absolutely love the 4-2-2 exhaust and really like the headlights as well.
I think this bike would look amazing if a Honda 2 round headlight Bol d'Or style front fairing (even just a bikini version) could be fitted.
http://www.vfrdiscussion.com/forum/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=10028
Welcome!
Nice to see the bike is alive and well. Maybe now we'll get to hear it? Could you post up a walkaround video of the running bike for us?
Let's see more of your project, and hear about your plans for it too!
Welcome! ...and thanks for letting us see that beautiful bike again. I'm with Seb, love to hear the exhaust :)
Me likey :cheerleader:
Keep it comin
End of thread · 50 posts recovered Wayback Machine snapshot 3 Apr 2020
