[image: View Post]Xtreme, on 04 June 2011 - 01:49 PM, said:
A new VFR owner registers with a question!
I bought a well kept 1992 VFR and was wondering about front spring preload adjustment.
Should the two screws be in identical position or like mirror images ?
My front end feels a bit soft and I tightened it a bit and it felt better. Before the screws were in mirror image like position, but after I adjusted I set them both to same position (3/9 o'clock).
Thicker oil will make the forks take longer to extend after being compressed... speaking in really simple terms, it's easy to imagine thin oil going through a hole... and then imagine thick oil going through the same oil... the thinner oil will go through much faster/easier... this is how the damping controls the forks in their extension phase... you hit a bump, the fork compresses and the spring will then make the fork want to extend... but if there were no valves (holes) and no oil controlling this extension, the bike would pogo-stick, right??
Yes it is true that in a layman kind of way, thicker oil in your forks will make the forks seem stiffer... but that's not really true. What they are is slower to extend in order to receive the next bump... so if there are multiple bumps, one after the other in a short space of time, after each bump, the forks will not extend to their full run-out (absorbtion potential)... and so on each time... so the spring will be more compressed as you hit successive bumps... you run the risk of chattering taking place as the springs never get fully extended to meet the bumps.
The only real way to have properly stiffer springs is by putting stiffer spings in... the springs are what hold everything in suspension.
Tightening or increasing the preload just puts the springs under more load... compressing them, and thus they will try to extend to their position of equilibrium. The idea is to give a certain, range of usability for different riders' weights... it's not econommically feasibly for the manufacturers to put custom rated springs in according to each buyer... as different spring rates would require different valves and different oil weights/densities as well...
If you are out of the spring's range of tolerable weights then the best solution is new springs with the spring rate to suit you (your weight, your gear's weight, pillion or no, hardbags, agressive or relaxed riding style).
Adjusting preload will help within a certain range of rider weight/riding style. The thing is, in the front forks there is no damping adjustment... not like in the rear shock. So if you increase preload, making the spring want to extend more back to its original position of equilibrium... it will rebound with more gusto... and unless there is a rider/gear weight reason behind the increase in preload, the forks will want to extend more briskly/faster... changing the oil to a heavier weight oil will of course attend to this... but unfortunately with the trade off I mention earlier... and this is like putting the cart before the horse.
One should get the bike properly suspended for weight/riding style and then set up damping parameters accordingly.. not the other way around.
But play around with the settings... the bike probably won't high-side on you all of a sudden just making some conservative adjustments... oh and remember, front affects rear and rear affects front... they don't work in isolation...
There is always a trade off with suspension... softer gives more plush ride but less control/stability when pushing the bike to the limits...
