pretty much all year the bike has been misbehaving once it's warmed up (ran fine when cold) at low RPM. revs would drop below a certain threshold and the power would drop off dramatically as the bike would then 'bog out'... increase the revs, it'd bog down a bit more, then the power would come back all at once.
felt like it was getting too much fuel at low rpm, but before i went chasing a potentially expensive problem in that regard, the fact that i ran fine last year before the winter/spring maintenance was still bugging me.
i'd ran across a good deal on iridium plugs (NGK), so those went in as part of the winter maintenance - can't remember how long the old plugs had been in...5-6 years and 60,000 km or so. never had a problem with plugs before, and never used iridium plugs before, so i wanted to swap them back out before i tried anything else.
picked up some convential NGK plugs, popped them in, and the problem is gone. the bike has that 'electric motor' pull from low RPM all the way up, like it used to.
can't tell you exactly what the problem was, as the iridium plugs i pulled out look pretty good (don't look wet). i'll throw up some photos of them when i get a chance.
i'd be interested to know if anyone has more information as to whys of this situation.
