I changed the fork oil about a year and a half ago (almost due to do that again) and set the sag properly for my weight at the time. That helped quite a bit...but...
The bike still has a pretty harsh ride, and at higher speeds when you hit expansion joints on the freeway or ripply pavement the ride can get pretty bouncy. Riding it on a rippled road or just not smooth road gets extremely uncomfortable quite quickly. I'm far from a suspension expert, but it feels to me like the high speed compression damping is way too stiff -- the bike doesn't soak up quick impacts at speed, but jolts everything instead -- but at the same time it will start a high speed bouncing feeling if the bumps continue. BTW, I used 10W oil in the forks with the stock recommended air gap.
It handles acceptably well in the twisties for being a fairly heavy bike, but I'd really like to see if I can get a cushier ride out of it. I have 27K on it now and I'm thinking the rear shock is probably shot. I simply can't afford the $700-$1000 for a new aftermarket shock, so what options do I have other than a new OEM unit? I've hear Progressive makes a cheaper unit, but I'm having trouble finding a company that sells one for the VFR. I can't really spend more than $400 on a shock.
I don't need a shock with a million adjustments because I'd never use them. I do need preload...maybe some damping adjustments.
As for the forks, I have no idea what to do with that. I don't need a high performance suspension. I want something that handles weekend blasts in the twisties but doesn't ride like a leaf-spring Jeep everywhere else. new springs?
All suggestions welcome.
