'97 rear sets?
4 posts Started 1 May 2012 Last recovered post 1 May 2012 Wayback Machine snapshot 10 Jul 2017
Looking to put some rear sets on my fourth gen '97 vfr. Think i found a post about it ages ago but can't seem to find it. Pretty sure earlier fireblade ones fit, but if anyone knows the exact years and any moding it would be really useful. Sorry i've been so quiet on my build, things have been a bit hectic, will take some photo's this weekend.
So 929/954 ones will fit? Distance between mounting holes need to be 78mm ish and m/c mounting 46 mm.
I don't think that 929/954 ones will work, as I'm fairly certain their mount points are closer together than the 78mm required. R-1 rear sets do work, but they really move your feet back more than necessary, and are rather uncomfortable because of the extreme rearward position. I believe that RC-51 rear sets will bolt up, but won't really give you any additional clearance. I'm looking at possibly geting a set of these, as the mounting plates can be flipped to change the amount of clearance vertically.
http://www.nobunaka.com/index.php?lay=show&ac=cat_show_pro_detail&cid=13707&pid=62819
End of thread · 4 posts recovered Wayback Machine snapshot 10 Jul 2017
