Ticking sound... valves?
7 posts Started 25 Jun 2012 Last recovered post 28 Jun 2012 Wayback Machine snapshot 1 Jul 2012
So my '99 has developed a ticking sound at idle. Barely audible at first, but over the last week or so it's gotten louder. Sounds like a bb bouncing inside a small container.
The bike just rolled over 16k, so it's technically due to its first check, but it would seems a little early; then again, it's a 13 y/o bike. I've also noticed the exhaust getting raspier and it seems to come from around the headers area. Is there anything specific to look for to diagnose?
That sound - well it sounds like an exhaust leak from here...do you have a stock header? You might have lost a nut. A leaking exhaust at the flange sounds like the BB sound you describe.
  Cheers!
Could also be the pair valve. Mine makes little "rink" sounds at idle.
I have TB headers/pipe. Haven't had a chance to dig in, but it's getting more noticeable. I ordered the PAIR blockoff plates figuring I was gonna do that anyway, and am going to play with the exhaust this week.
I've also noticed that the exhaust got louder and rasper, and there is a drop in perfomance. Like when giving some throttle at 6+k rpm it goes, but seems to struggle a bit and sounds like it's doing more than it is.Then again, I  might be keeping the RPMSs lower than normal due to the noise. I do remember noticing a power drop one day recently before this even started though.
What's a good way of diagnosing if it's an exhaust issue? Just remove the whole thing and put back at first?
Is there an example out there of what the valve clearance noises are like so I could rule that out or other symptoms?
Oh, and I noticed that the exhaust is leaking through the rivets on both sides. Could this be an issue?
Could be a stretch but I've had ticking noise occasionally that clears up (mostly) with a can of Seafoam. Think it's a bad/clogged/malfunctioning fuel injector. Could explain your power loss issue too. I'd guess that before the exhaust leak.
I remember reading the occasional tick sound at idle had something to do with gear driven cam assembly.....
Just bear in mind as valves wear the clearance gets smaller not larger so it wouldn't create a tick. Other suggestions all seem valid. Sea foam is cheap and easy start there.
End of thread · 7 posts recovered Wayback Machine snapshot 1 Jul 2012
