thought i would try the nc30 seat cowling on the vfr it fits almost perfectly i have raised the rear subframe about an inch to make the panels on the seat line up with the vfr tank all you do is undo the bottom subframe bolts and make a short bracket the rear light has the same bulbs as the vfr they go straight in also i dont have to moove any of the electrics that sit under the seat on all i had to do is bend the two seat mounts down a little they are the ones that that fasten to the side of the seat
i will remove the rear peg hangers make a bracket for the silencer redrill the nc30 front mounting lugs and thats about it.
get it painted in red one other thing i had to do is grind a shallow angle on the rear subframe at the rear nothing drastic.
- [image: my 97vfr moded.jpg]
