I can remember swapping out the rear shock on my 97 VFR (same style as yours) and it took me about an hour to undo the shock, remove and re-install the unit. I had sent the shock away to be resprung as I'm not sure you would want to try and install the actual spring on your own unless you have a spring compressor (those spring are under a lot of tension and without the proper tools, you could hurt yourself). The rear shock took a little more than a half hour to remove (never having done it before) since it was only four bolts to remove and then about another half hour to re-install the shock once I got it back from the company that rebuilt the rear shock for me.
As for the front shocks, I have never changed the springs in my forks so I am not really sure how long it would take but after reading the manual it does seem a little complicated, especially if they have to remove the forks to do the swap which I believe they would. I don't think 5 hours labor IMO is out of line as far as time goes, but that is likely book rate and that is just what the standard labor rate is for those particular jobs. May not take that long to do, but that is what they say it will take, so that is what you will pay as far as hours of labor goes.
If I were you, I would consider giving Jamie D at www.daughertymotorsports.com a call or sending him an email. Jamie is a member of this site and he built a shock for my 2000 VFR800 that is more adjustable than the stock unit and has a higher rate spring. I commonly ride with my wife on the back and between the two of us we weigh in at around 325 lbs and Jamie installed an 1100 lb spring as I recall. Jamie is an excellent guy to deal with and I'm sure he could offer you a tremendous amount of information on how to improve the suspension on your bike. Just adding a stiffer or stronger spring to the rear shock, I don't think will make a very big difference unless the shock is also re-valved to match. Instead of a spongy pogo stick you may wind up with a really bouncy one instead and I don't think that would be beneficial to you either. I am certainly not a suspension expert but JAMIE D. most definitely IS, so drop him an email and see what he has to say.
Good luck with the suspension swap and all the best.
The time quoted seems reasonable to me, so for you it is a choice if you have/want the pennies to have it done or like to get your hands dirty... :-)
If you do want to do this yourself, download the manual for the 90-97 here on VFRD. If you do decide to let the garage do it, you give them the relevant pages (if they are not a Honda dealer)
I would stay away from trying to fit a different coil on the rear shock, unless access to somenone with the right tools.
I also went the Jamie D route. I sent him an OEM ABS shock to have him revalve/respring it and send me the spring/shims for the front end. I did the rear shock install in less than an hour and a half and the front took me the better part of an afternoon, but I also had to disassembled the fork innards to replace the shim stack(s).The amount of time the shop quoted you seems about right if they are also changing the spring on the rear shock for you. However for a little more than what you would be paying them, Jamie can revalve the front and rear for you, at least that was my case. If you have any mechanical apptitude, you should be able to handle the "installation", but unless you have the proper tools, I would probably say replacing the rear spring should be left to the professionals.
Any shop worth their weight should be able to do the job, not including time if they are already busy, shouldn't take them more than 10 minutes max.. Shouldn't cost you much either.
If you're just replacing the fork springs and not the oil you can do that on the bike quickly. I assume the shop quote includes removing the forks to remove the old oil, clean and put new in. That and the shock install sounds like about 5 hours.
HUH?
If the shop tells me they did the front and rear swap, in 10 minutes, I'd say they did SFA.
Just drank a cup of coffee and charge for "work done"...
Did they perhaps mean fork oil? If they include replacing fork bushings, seals and putting new grease in the rear suspension bearings, 5,5 hours doesn't sound too bad.
End of thread · 11 posts recoveredWayback Machine snapshot 21 Jun 2015
