As most of you know who attended the 10th annual Texasmac, I've got a pretty big project ahead of me and only about 360 days to finish it. I'm planning on attempting to put my 5th gen engine inside a 6th gen frame and i've seen one guy post a thread about it on here before but can't find the post. If anyone can find the link I'd appreciate it. Just wanted to read it a couple times before i dig myself another financial hole.
Although I don't have the link, I remember it was an Englishman on the British (or European) VFR forum that did it. If memory serves, what made the job more difficult than he anticipated was that many connectors (e.g. electrical, cooling system, etc.) didn't match up (he still got the whole thing to work, though.)
Although he spent a lot of time on the project, I don't recall him saying it cost him a fortune.
What I can recall is this: he used the 6th gen chassis, 6th gen ECU (W/ power commander), 6th gen wiring harness, 6th gen throttle bodies and airbox, and of course, the 5th gen engine.
The (rear?) valve cover interfered with the frame IIRC, and it had to have the breather/baffle section cut, modified, and welded.
That's all I can remember from reading the thread on UK Biker's Oracle VFR board.
"My VTEC runs sweetly with an FiX lump in, but everything else is original VTEC particularly the throttle bodies, etc. I had to modify the cam covers to accommodate the coil packs . . . "
Fifth gens have remote coils and 6th coil-on-plug setup. Mark J. Harris is the guy you're looking for that forum.
Should be an interesting project. Please keep us updated.
The thread is hidden away in a members only part of the site. There is something like 320 odd posts so it might be worth becoming a sponsor just to read that thread!
I got the impression mark would not attempt it again...
Thanks for the replies, I recalled that he had to modify the frame near the rear cylinder but cutting and welding the breather/baffle section makes more sense, thanks Rob.
Thanks to all of you guys for the feedback and direction.
He has the entire bike disassembled and is washing the mud off of the engine in the driveway now...as I look out the window he actually has the injectors off also and the frame is laying about next to the truck. I am not sure if it would be worth the effort but he is stubborn.
Perhaps this is equally suited to the TXMac Quotes thread, but I do believe my one notable contribution would be "He's not called MiniCarver for no reason."
And that was before the whole rebuild thing was floated...
I have bolted a 6th gen frame to a 5th gen engine without issue(and that's as far as I got!). If I were to do this project I would try to keep the 5th gen engine management with the 5th gen engine, and leave everything else 6th gen. You could always convert the ignition to the Denso stick coils to avoid trying to find a place to mount the bulky 5th gen coils.
Hi, new to this forum and I just wanted to add to this thread that I have viewed many times. I was a Honda dealership mechanic for 26+ years and always a v4 nut. I acquired an '01 vfr800 motor and chassis some years ago with the intent of swapping into a gen 6 frame or building a racebike. It sat on the back burner until last fall when I purchased a nice 04 with a blown motor in Seattle. and after reading various threads on the swap, I got started. There is NO modification needed to the engine or chassis, it bolts right in with no issues. I used the 01 wiring harness and ECM with the 04 fuel injection rack and a power Commander 3 PC. Wiring and relocating the ECM to under the seat were the biggest challenges, but not that difficult. The 04 gauges were pretty straight forward to wire to the 01 harness. Delkevic header for an 04 fits the 01 motor perfectly, and mates up to the 04 Two Brothers system that was on the bike. Mounts for the 01 coils were easily fabricated, space not an issue. Deleting the ABS and delinking the brakes created extra space, especially under the seat. Can post pics if anyone is interested. Thanks for the great forum!
Hi, I didn't support the back of the bike when the engine was out, I built a wooden box that fits around the oil pan and put it on a floor jack. Unbolted the swingarm and motor which was secure on the floor jack and lowered, then having reattached the subframe I removed the frame wheelbarrow style. It helps to have an extra body.
This is, of course, useless without pictures! :goofy:
Seriously though, well done. How does the bike ride?
I can't seem to find the more detailed pics from the build, I'll take some more when I have things apart again. It will definitely outrun the 07 vtec bike that I have. So far no problems and everything works great. I'm already planning another lighter version with 929 swingarm and forks.
Any thoughts about doing valve adjustments on the rear head - with the shorter heads it doesn't appear that the 6th gen inspection port is going to line up to provide a view of the 5G timing marks.
You don’t need the timing marks for valve measurement. Just look at the cam lobes, when the tip is opposite the bucket, you can measure the gap.
If you need TDC for cam removal/install then a piece of alloy rod or a long screw driver down the plug hole will give you TDC indication. If you use the paint method as advised by Honda, you can count teeth from the head face to the painted teeth ends.
There is always a way if you put some thought into it 👍
Update- Several thousand miles later, Bike runs great! Had to relocate one of the rear coils to the rear of the airbox after it rubbed one of the connectors and developed a short. Had to replace the clutch-miles were unknown on the 01 motor, and the plates were in pretty bad shape (started slipping after some practice drag race starts). Starting my next project- 02 also getting an 01 motor, this one will have a 929 swingarm and forks. If anyone is in need of a 50k mile 02 motor, ecm, coil packs etc., 02 forks and brakes, 04 ABS stuff, I got 'em!
