Difference In Helibars
6 posts Started 26 Jun 2013 Last recovered post 5 Jul 2013 Wayback Machine snapshot 2 Apr 2016
Since I have been looking for Helibars, I have seen the old style pop up more frequently. I checked the Helibar website and they really don't detail the differences.  can anyone who has seen both of them in person, or maybe even used both of them tell me exactly what is different between the old style and the new revision?
Old Style
[image: helibars.jpg]
New Style
[image: HB01003%20-%202.JPG?itok=YRlN2K6l]
Obviously the pinch bolts are different, but that is all I can tell.
I had the old style on my 2001 VFR and swapped them for stockers...IIRC the newer ones have about 3/4" more height and pull back another 1/2" over the old style.
Aha, precisely what I wanted to know. Thanks! You just saved me from buying a set that aren't what I want!
Is the angle different? I have heard some 7th Gen owners complaining about the angle on the Helis
There's also the obvious difference of one pinch bolt vs two.   When I got mine (single bolt style) the instructions listed 2 different torque specs for the bolts and admonished in bold, capital letters that it was imperative for safety to torque them properly.  I contacted them and they rather sheepishly called me back and admitted that a mistake had been made in the instructions.  Double check the spec if you're unsure when you install them - it's different between the two.
The difference between the new style and old-style is the one with only one Pinch bolt that allows you to raise up the bars little bit higher which was the most popular request from owners. I believe that the heli bars are 1 1/4" taller and a 1 1/2" closer to rider.
I am more than likely going to order a set very soon as doing a 5000km ride soon to sturgis and around. I will keep u posted on the difference
End of thread · 6 posts recovered Wayback Machine snapshot 2 Apr 2016
