Gps Mount / Device Mount On The Viffr
25 posts Started 5 Jul 2013 Last recovered post 4 Aug 2013 Wayback Machine snapshot 18 Sep 2017
Hi All,
Has anyone installed a gps / device mount?
Where did you install it? What positioning is best?
After making several u-turns on my last trip I've decided it's time to 'ask for directions' and mount my android phone.
I'm looking at this so far:
http://www.twistedthrottle.com/ram-b-238-diamond-plate-base-2-25-x-1-25-base-with-1-diameter-ball-required-for-all-device-cradles-when-used-with-a-ram-arm
http://www.twistedthrottle.com/ram-x-grip-universal-spring-loaded-universal-holder-w-1-ball
I can't find the link to it, but I bought a waterproof gps mount that connects to the steering stem with a one inch ball. The glass is terrible, and it rubs against my tank bag. I am buying a RAM arm and ball to ball adapter to try and make it work better. I know this may not help, but it's my experience.
If you haven't already, look at the RAM website. There has to be something there that will work for you,
Adaptiv technologies mount (has built in vibration resistance) with a Ram X grip universal holder. Excellent setup
There are tons of ways of doing this - and you'll get a lot of responses with various ideas. I bought one of these
[image: RAM-B-149ZU.jpg]
http://www.rammount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045066045049052057090085/Default.aspx
The bracket holes for the U bolt line up with the tank mounting bolts. I got some longer bolts for the tank and bolted the bracket down with the tank. Then get the appropriate adapter for whatever GPS you have and you're good to go. Some people like the mount that fits in to the hole in the steering stem, but that's where I have my powerlet to bring power to the GPS unit, so that didn't work for me. I've done about 7,000 miles with this setup and it's rock solid. Shop around on the Ram website - there are numerous ideas for fixed mounts that don't move as you turn like I did, mounting in the steering stem or mounting to the clipons. Some people also like to put them in the clear map pocket in their tankbags or suction cup them to something - I remember one guy that suction cupped it over the tach and another that somehow rigged it to the inside of the windscreen. There are tons of options.
This is what I did, drill two little holes in the windshield and through the broken suction cup mount and there it is
[image: IMG_0078.JPG]
[image: IMG_0077.JPG]
[image: IMG_0070.JPG]
I had something similar years back. Really liked having the GPS up high on the wind screen.
[image: 6 Stock GPS screen for touring.jpg]
Then, got a smoked screen and just didn't want to drill it so I picked up a Ram Mount, installed the base ball in the gas tank bolts.
Use a 5" Ram extender and Ram GPS mount which holds it at a decent height not blocking the dash and over my tank bag (when used).
If you visit Ram Mounts website and go to the motorcycle page, there are a variety of image samples of what others have done, to inspire your ideas.
Linky: http://www.rammount.com/Products/MotorcycleMounts/tabid/128/Default.aspx#/
I think Monk has a nice Ram mount setup that he's posted pictures of. I do like the high windscreen mount, not sure I can bring myself to put holes in it yet though :-)
I used a slightly bent clip-on handlebar to make a mount for all my gadgets:
[image: IMG_3710_zps7f4f0dcb.jpg]
Comes off easy, and works with any standard 7/8 handlebar mount. There is a piece of heater hose with some washers, and a long bolt with nut on the end running into the steering stem that holds it in place.
I have Convertibars on my 2004 and there wasn't a place to put a handlebar mount so I went with a RAM ball that bolts to the top of the clutch fluid reservoir. It comes with longer bolts and spacers and taking off the reservoir cover isn't any more complicated than without the mount. On top of that is a RAM 4" arm, though it's actually about 3.5" center to center on the two balls. Then there's a RAM clip-in GPS mount that's specific to my nuvi 500.
It works really well once you get it adjusted properly. It clears the windscreen on a complete sweep, puts the GPS up fairly high but still protected by the windscreen, is out of the line of sight of the instruments and is just above my left hand. I power the GPS from an unswitched Powerlet in the stem.
[image: post-22790-0-82504500-1373045165.jpg]
[image: post-22790-0-94751000-1373045166.jpg]
[image: post-22790-0-98432500-1373045167.jpg]
[image: post-22790-0-99607200-1373045168.jpg]
[image: post-22790-0-23441100-1373045170.jpg]
Thanks everyone for the posts.
I like this idea! Not too invasive. Swfarrar, does the gps sit completely behind the windscreen?
swfarrar
swfarrar
That setup is impressive to say the least.
Here's one I prepared earlier (2005):
[image: post-362-0-86623000-1373546778.jpg]
[image: post-362-0-01531700-1373546800.jpg]
[image: post-362-0-31940100-1373546842.jpg]
[image: post-362-0-52900200-1373546898.jpg]
It works with a Bagster tank bag and cover, so in theory it is portable between my bikes (only needing appropriate electrical connections). This particular set-up is no longer in use (note the state-of-the-art Garmin 2720!) I had the tank bag set up with HID ballasts, Autocom intercom, Touratech IMO, MP3 stereo and Bluetooth phone interface, but the "sled" holding the head units was really a last-minute idea I had as I was running out of time to prep the bike for a European tour. Heavy duty adhesive Velcro was used on the bottom of the tank bag and the top of the sled--it held and has not even peeled in over seven years. The tubing is 7/8" OD alloy, the sled is stainless. As I recall, there was some bouncing on rough roads, but probably less than if the head units had been mounted to the bike itself. Location was great. Up and out of the way. :happy:
Wow, I thought my radar + GPS (iphone) mounts were cluttery! :unclesam:
I just bought a TomTom which has a permanently attached ball socket with a suction cup for attachment.
It has a dial or whatever above the suction cup that you turn to pull the cup in and make it stick to the windshield.
Not sure that's a good description, but it works easy in my truck.
For the VFR was thinking about using the stickon smooth disk they include for mounting with the cup somewhere that's not smooth.
And putting it on the horizontal part of the fairing under the handgrip. It wouldn't be in the way I don't think,
but would not be easy to see at a glance. Should probably get a bluetooth headset too. Hmm. :wink:
I have the LSL bar conversion so a short arm and RAM mount for 7/8 inch bar and a cigar lighter that mounts to that bar works great. Mine slightly covers the speedo but the GPS speedo is WAAYYY more accurate, so I don't worry about it.
Edited July 12, 2013 by dalesvfr
The bolts for the RAM ball are the same width as the front tank bolts. I just bought slightly longer bolts. It fits nicely right above the top clamp and doesn't block my view of any of the gauges.
[image: post-18041-0-27529600-1373590346.jpg]
Edited July 12, 2013 by xDutchx
of couse, i dont ride around with all that on, that was my demonstration of what i have...
I have a rigged set up using GoPro adhesive mounts so that I can install/remove my Galaxy S4 from just under my windshield. I've found that as long as I use the phone as the "brain" of the ride I can have everything right in front of me on the fly (including navigation, music, speed, altitude, compass, average total speed, average moving speed, top speed hold, total trip distance as well as total trip time).
When I have a chance I'll take a picture for you.
-Drew
luvtoleanit
Maybe so, but with the only connection to the bike being one large waterproof circular connector, I could unclip the tank bag and remove everything valuable from the bike in less than a minute!
swfarrar
The motorcycle reservoir cover ram ball mount base is a great idea. I've been looking for something like this so that I could mount the GPS and still run steering stem mounted steering damper. Thanks for the suggestion!
http://www.amazon.com/Mounts-Multi-Fit-Reservoir-KAWASAKI-SUZUKI/dp/B003CMNXIO/ref=sr_1_1?s=automotive&ie=UTF8&qid=1375575727&sr=1-1&keywords=RAM-B-346U
I built this for my 1st gen the day before I left for a tour to BC. I used an existing hole in the bars, bent some 1/4" round and threaded the ends. Bought a phone cradle with a suction cup mount, cut the arm off it, and threaded the cradle for 1/4" threads.[image: post-22926-0-65134500-1375579012.jpg]
Had to fiddle a bit to get the angle right, but it holds my iphone or BB quite securely. I could turn it sideways an use it for a GPS in the future.[image: post-22926-0-49310900-1375579031.jpg]
[image: post-22926-0-13689700-1375579045.jpg]
And yeah, I have to polish or paint it yet. I'll leave that chore for winter.
Edited August 4, 2013 by Grilldemon
My super easy GPS mount:
[image: DSC04650.jpg]
End of thread · 25 posts recovered Wayback Machine snapshot 18 Sep 2017
