Well, we got together as planned and after I showed him my bikes and shop, he got out the box.
[image: 2013-10-18165239_zps71609b7b.jpg]
[image: 2013-10-18165307_zpscb8bda3c.jpg]
Then we commenced to unpacking it. I don't think he had ever opened it since he bought it way back when...
[image: 2013-10-18165416_zps58523308.jpg]
As you can see, it isn't a stainless system. The pipes appear to be painted with high temp paint or maybe ceramic. The left side has a small bit if light surface rust starting to show near the end closest to the cannister. Fortunately most of it is on the backside and some careful prep work and touchup with the right high heat paint should make that go away.
The cannisters look like they're brushed aluminum; a magnet doesn't stick to them and they show slight signs of aluminum oxidation in a few spots. Those will be easy to brush out with the right abrasive material - something like Scotch-Bright.
[image: 2013-10-18170636_zps7eaed9bb.jpg]
I guess the thinner you make the end caps, the quieter it sounds. These are in unopened packages...
[image: 0b4a6031-201b-4f98-9056-2213bcf4952d_zps]
All the bits and pieces are there but there are no installation instructions. Most of it appears to be self explanatory, but I would like to know the correct way to bolt them onto the hangers. There's a little tube of high temp lubricant that I assume is used for the ends that slide into the cannisters?
[image: 2013-10-18185252_zpsfeeb06fd.jpg]
[image: 2013-10-18170746_zpsc5f1c365.jpg]
Included was this carburetor recalibration "system" otherwise known as a jet kit.
[image: 6cf76c8a-7255-44cf-9be2-970a16b103cb_zps]
Do these need to be rejetted if this exhaust is used? I'd really hate to have to pull those carbs off again after all this bike has been through.
[image: 2013-10-18180438_zps721ea161.jpg]
Overall, I'd say that this was a nice find and something that might look nice on my bike. You're probably wondering if I bought it, eh? ;)
[image: 2013-10-18175419_zps37f5d3cc.jpg]
Edited October 18, 2013 by tomk1960
