What A Great Bike!
35 posts Started 9 Jul 2014 Last recovered post 17 Jul 2014 Wayback Machine snapshot 1 Jul 2017
This low mileage 98 I picked up is just now legal and after my first ride to work I have to say this is one hell of a bike! Very well rounded. Does everything good! Handle great as is and very confidence inspiring. Pretty darn fast. Doesnt stop GREAT but does stop good. A little extra effort and she slows down fine. Good to look at as well. I like curves better then the newer angular look.
Coming off an airhead BMW R100RS it's like night and day.
The view out my window at work through glass and cropped. BAD quality but again you all know what they look like! This one is about bone stock.
[image: IMAG0618_zpsbogpyvfq.jpg]
Edited July 9, 2014 by JimGregory
Preaching to the choir! Congrats on your new ride and Welcome Abaord!
Always a pleasure to view rounded red beauty's from behind!
Especially bald shaven ones! :beer:
Hey those are BRAND NEW dulop Q3's on there. The pic makes them look bald and flat spotted but they are neither. She leans and flicks and sticks just like a good girl should.
The PO just put them on to replace the half worn OEM tires that had no grip at all after 16 years. I didn't pick them but they seem fine to me.
I park under that tree because it shades the bikes for most of the day. I'll take a little pollen over UV anyday.
Nice ride - welcome aboard !
Congrats and welcome aboard!
"Doesn't stop great" ...I'll say, you barely got it stopped up the pavement without hitting that fence or tree! :goofy:
If the PO have 16 year old rubber on it, the clutch and brake fluid could probably use refresh as well and you will find that the 5th Gen can stop as well as any in the world (I believe it was Motorcyclist mag that had the bike listed top 5 of all time in braking distance - date accumulated over the years).
when you stop riding it for the winter it could surely use a fork fluid change and perhaps a respring depending on your weight.
Enjoy!
CornerCarver
Enjoy!
As I said I tuck it in there to keep them out of the sun.
The PO said all the fluids were changed. No paperwork accompanied any of this but he was a good guy. Oil looks good. Brake fluid looks clean. Dunno about anything else yet. Been riding her for only..lets see..one day. But I am not opposed to KNOWING whats in where as soon as possible. Dot 4?
The forks feel great but I am sure that is 13 YO oil in there. Why the hell there are no drain screws I don't know.
Welcome to the asylum JG. You've got great taste in motorcycles - best generation in the fastest color. Nice score! I'm taking your touch-up paint to the postoffice in an hour.
Three sets of EBC HH will make her stop...
MaxSwell
Thanks Max! Who's better then you!
CornerCarver
Enjoy!
Just spoke to PO. Brake fluid, Motor oil, Coolant all done about 1500 miles ago. Forks not so much. But really they only have 3700 miles on them now. I reckon there have been a few that went longer.
And yes EBC may be the asnwer.
JG, if you're a "do it yourselfer" be sure to download the Honda Service manual from the downloads section, it'll come in handy, especially if you take on bleeding the linked brakes! Should also come in handy if/when you tackle the forks.
Cheers
JimGregory
CornerCarver
Enjoy!
Word is, you can do a fork oil change without pulling the forks out....does not require flipping the bike over, either!
If you support the front wheel off the ground you can pull out the axle and then get access to the damper rod bolts at the bottom of the legs. If you undo these the oil will drain out. There's no need to pull the wheel or brakes out. I haven't done this myself but have checked that the damper bolts are accessible (6mm hex required).
Terry
JimGregory
CornerCarver
Enjoy!
Ya I was thinking in that direction. Seems easy enough.. But she's so well behaved I believe that will wait till the cold months. I am finding little things..fasteners missing, little plastic bits broken..like the tool kit tie down. The battery cover has issues. Nothing real problematic so far but this is really only day one with it.
Yes Mr Duc I have already ebayed a service manual but thanks for the heads up on the download. Reading on the laptop is almost entertaining.
I did notice on the parkway this evening when the revs get up there is quite a buzz going on. Like 110mph in high gear she was vibrating pretty good.
also same rpm in lower gears produces vibration. Is this normal?
110 in top gear with stock sprockets should be around 7500-8000 rpm IIRC...it can start to get a bit buzzy there but nothing untoward.
As you spend more time getting used to it and perform more in-depth maintenance this winter you may find some vacuum hoses deteriorated and leaking.
It may just need to be broken in and have some deposits blown out with good quality fuel (100% if you can find it readily).
welcome to the forum!
Chain may be getting a little past it's prime in age and miles adding some "buzz" at higher speeds...
Welcome!!!
gr8vfr
+1. Add some good suspension, and you will be amazed how much better she can be.
Thanks for all the advise and welcomes. I must get to know this bike for a while. I suspect there is something going on with the brakes but I will need to find some time to get into it. I think it's important to know what you have before throwing money at it.
I do KNOW I have to do something about my junk getting mashed into that tank. Maybe time will cure that. I never had one of the humpy tanked sporty bikes before!
You could try putting grip pads on the tank and gripping with your knees. Mine will stop from 25 MPH in less than 20 feet, without crushing my delicate parts. Pretty sure the brake pads are OEM. Lots of practice of hard stops is a good thing. Anyway, welcome and enjoy!!
Well after a brisk ride to work on the parkway at speed I didn't notice vibration much at all. Just well behaved handling. When I DID notice it, was while carrying my girl on the back last night going to dinner. No girl equals much less vibration. Hmm..wonder why.
However I got off the highway and did my bob and weave routine to get positioning at the next traffic light. A cop in his off duty car pulled up and reamed me. I lifted my face shield and he said "how old are you!" I said 59. He said I thought you were 18! Anyway it was a pretty good wake up call I guess. This bike is deceptively fast.
My problem is that I have found the best way to deal with traffic is to get the hell away from it. The last crash I had was sitting at a light with my turn signal on and an old lady just plowed into me knocking me on my rump and parking a bike on top of me. I don't like cars! I like to go around and get away. I guess I have to rethink this. I did feel like I was 18 while I was getting reamed this morning. Day 2 with the bike only half way done. Jeez...
Oh and a large truck pulled into my lane on a secondary road. Acceleration was my friend just then.
I must slow down
I must slow down
PS I have a half bra coming sometime soon. Maybe it will help my knees grip the tank. Also a Sargent seat. Hope I like it.
JimGregory
I feel the same way, but sometimes it's better to watch the pack of inattentive idiots from behind until there's a good opening. The more space I have between me, and the cagers the better. I know I can out accelerate/maneuver them, but I can't out brake them especially if they start smashing into one another. I don't want to be collateral damage.
Avoid the pack mentality.
JimGregory
Wait, you're telling me that my VFD is sporty bike with humpy tank?!
Coming from a "Balls Crasher" CBR600RR, the VFR tank's hump couldn't feel any comfier :D
Edited July 11, 2014 by raoufhakam
[image: humped-zebra-crossing.jpeg]
MBrane
JimGregory
There is always more idiots behind you. It's a never ending stream. You cant provide for every eventuality but you can try.
raoufhakam
JimGregory
Wait, you're telling me that my VFD is aporty bike with humpy tank?!
No no I said MY bike is humpy..never met yours. And I would never call it portly. That's just rude!
Sounds like a good low mileage buy. Amazing what you can find in the States!
A couple of years ago I bought a small trials bike from the early 90's to fool around on and the brakes weren't all that great. So I stripped the calipers and found mild corrosion behind the seals in the calipers. Used a dremmel with a brass brush and it cleaned out like new. Brakes worked noticably better afterwards. Maybe your's are OK, but maybe worth checking over winter.
As for EBC, I have had bad experiences with their products before (pad material coming unstuck from the pad in chunks & very short lifespan compared to others). You might want to look at Brembo sintered pads or other alternatives, but then if you're running OEM pads still, those should be pretty good anyways.
There are various tank grip materials out there. Something like this can be cut to your desired shape (Make a paper template first) and stuck onto your tank. Clear would work well on your red VFR. http://www.stompdesign.com
Edited July 11, 2014 by TheStig
There is a year 2000 yellow VFR for sale locally with 2600 miles. He wants about a third again more then I paid though. But it looks quite nice!
JimGregory
Oh ok sorry, i thought my 5th gen VFR800 could be somewhat similar to you 5th gen VFR as well, sorry, my bad :P
raoufhakam
JimGregory
I hear they do share a family resemblance..
emoyer
Any recommendations for good tank grip pads for a 5th gen?
I got the techspec ones. I think they might have actually sent me ones for a 6th gen, because they are a little too "pointy" on the front, but they work well.
Welcome to the exclusive club.
TNRabbit
http://flexinno.com/shop#!/~/category/id=426073&offset=0&sort=normal%C2%A0
They don't list a VFR in the Tank Tredz ... did you use the universal kit (medium or large) or did a model specific kit work?
emoyer
Which type did you use? Snake skin, High Fusion, etc.? Any pros and cons to the different grip surfaces?
Rush2112
TNRabbit
emoyer
I haven't ordered it yet but was going to get the generic one.
End of thread · 35 posts recovered Wayback Machine snapshot 1 Jul 2017
