New 97 Vfr Owner, Getting Hot While Idling?
Hello Esco,
Welcome to VFRD from across the pond.
My '97 4th gen's fan kicks in only when the needle is well beyond the half way point.
In very hot weather like today (34 celcius) and spirited riding, the fan occasionally comes on at a traffic light.
I have yet to hear of a 4th gen engine going kaput.....
I recommend you check the wiring from the stator to the voltage regulator to the 30A fuse next to the starter relay for any signs of melting discoloration.
Mine never had any issue, but other have had. I pre-emptive fitted a "VFRness" (use the search function).
Other ttat that, check state/age of tires and chain/sprocket.
Oh yeah...
WE NEED A PICTURE!!!!
I think my fan comes on when the needle is very close to the top of the scale, one quick way to test the fan is unplug it put 12volts to it & verify it works then check the thermo switch....
Good Luck
Never on mine. I think the highest I've seen is about 3/4. Not sure when the fan comes on though. I don't do much city or stop-and-go riding these days.
I never saw it go any higher than that. Having it come up all the way to just under the critical zone on the gauge is certainly not normal, as all the years I owned my 95, it generally ran towards the cold side, especially on the highways even at high speeds.
In addition to checking/replacing the thermoswitch, I'd check the whole cooling system for any air cavitation or blockage. And if you haven't changed the coolant in a long time, this will be a good excuse to do so....
BTW, IIRC, 1275 RPM is the idle spec indicated on the service manual for the 4th Gen....
Another thing to check is the fins on the rad itself, especially the back side toward the engine. You can buy a 'fin straitener' from Harbor Freight for a few bucks, well worth the time to increase the efficiency of the radiator itself. The fins get buggered up when folks do plug changes.
once you have done the above and realize the bikes just run hot in start and stop traffic.
unplug the black wire from the fan to the thermo switch..
splice in another black wire to a switch, located at the place of your choosing.
add a ground wire from the switch :comp13:
live happy ever after. :wheel:
[image: IMG_20140404_004922_zps2b485cd4.jpg]
check to see how much anti freeze is in the system as well.
I need to correct my earlier post; the fan comes/came on yesterday when the gauge was "half way"...
This was after a spirited ride, cruising in my home street...
My VFR (1997) can run a little hot but not that much. It'll not go above half-way on the temperature guage and the fan comes on then. Or else some riding at speeds above 40mph will get air moving and ge tthe needle back down.
Is it worth putting on a fan switch? Anything over 20mph would be quicker than the fan would it?
