Can anyone help diagnose the cause of this? I've had the carbs off, I'm guessing there's something wrong with the slides, especially the one that doesn't move. Could this be down to balancing issues?
http://youtu.be/xHzx...tSO3xH17OdouAsg
The diaphragms are junk. Removed the carbs and they're all loose, must have been something in the fuel as I cleaned the carbs fully not so long ago. Ugh, more money to be spent on replacement parts then!
I'm very confused. What do you mean by "they're all loose" ? They are rubber and are supposed to be nice and soft and pliant. Only issue would be if they hardened or have any tears in them.
if your diaphragms were junk, you'd know it. Those you have are not. It would appear to me that the needle is stuck on the one carb and nothing more. Like it was mentioned, take a screw driver and gently push the slide up. I'll take a guess and say there is corrosion of some sort on the needle.
Lilongwe nosed pliers...
Must these pliers come from the capital of Malawi? :unsure:
or is Lilongwe the aboriginal word for long?? :unsure: :unsure:
Me think a total rebuild is what you need.
But it will be a great bike .
Haha, trust me...they're junk. The rubber diaphragms have lost their shape, there's a lot of slack between the outer ring and the base at the slide - so little so no suction is happening.
The diaphragms should move all the way up without issue - this isn't caused simply by a 'stuck needle', that's one of many symptoms that can stop the slides from moving. I just needed to remove the carbs to confirm this which has now been done. So some used carbs are en route from a relatively low mileage bike which should solve the issue. I'll upload another vid once they're on to prove the point.
