Rc45 Turbo Rc46 Turbo
25 posts Started 23 Sep 2014 Last recovered post 26 Sep 2014 Wayback Machine snapshot 29 Nov 2022
wargen
Thanks everybody, hopefully this video from 0,7 bar bost ,
And more Picture comming
OMG :ohmy: that is awesome!!
It's a hell of note when you have to let off the throttle so the front wheel touch down .
Rush2112
Wow... great opening post!!!
Welcome... I can't wait to hear more
Maybe the best opening post of all time - easily a top 10!
There's also all the other mods (which look to be too many to count) . . . we need to see this bike with its clothes off!
No i have no plans to offering kit…. sorry
I will post more picture and video later
Apart from the obvious front end, suspension, electrics and rear sub-frame, what else have you changed?
wargen
I think that's wise. A member here (Dan) created a of a supercharger kit for the VFR800s (both 5th and 6th gen) and some people were saying that they'd buy two if he ever started production. He did, and guess what, few people bought one. Granted it was a considerable sum that he was asking for, but I think that kit was easily worth that money. I was one of his customers and it really was a great creation. However I had some problems eminating from my bike (not the kit) and I gave up after a while and sold the bike and the kit seperately.
I'm always left in awe after I see talented and knowledgable people create stuff like this. Looking forward to seeing more of your work...
Hi, good thinking, there is hour and hour to figur out ingnition map, and hours to make a exhaust system so i took me 2 year of everyday work ok some day only 1 hour and some day 14 hours. If i make one more bying a frame for RV45 is not everyday shoping, you could use vfr chassi bits but count about 6 month work for me. No one will pay that( i think)
So you have another missile for NORAD to track.....NICE!!!
Do you have an intercooler loop in your design? and is there circuitry in the EC you are using to accommodate and control nitrous oxide as in one nozzle in the intake plenum or multiples
And a suggestion for extending your turbo chargers life ( a lesson I learned in owning 2 hi perf turbo cars) ..install a post engine shut off lube system...even though your crank isn't turning, the turbo can still be spinning at 10k rpm at shut down...without pressurized oil to lube it.
here is just one of many available kits .non specific for m'cycles.
http://www.autoenginelube.com/prepostlubekit.html
Good luck with your very advanced development ..
Ahh.. Holy shit batman....I want!!!.....great project...sound bite gave me chills......its my ring tone now...thanks and your bike is b e a utiful
Skids
sixth gen vfr swing arm?
Ok god question, here is some bakground, i dont want to change te geometrics in orgininal RC45 i can drive it in my sleep, but when power output become higher and higher during new parts in engine for example the double injection ( talking race kit only) the swing was 2cm longer (also HRC kit) to handle more power. And that is exacly the lengt of 2002- vfr, but the orginalRC45 is same length as 1998-2001, so i decided to go for 2002- to handle more power output, so its 2001 engine 2004 swing and 2005ABS controler, frame is RC45 posting more pics later on, the first engine was 2004 vfr but that was dubble work to make mapping when no vtec or vtec on, so i decided to make powertest with that engine and piston breakdown at aprox 330 hp but maybe my fault do to to smal fuelpump it was rated 350hp but anyway it cracked, oil pump is god idea i do have an electric waterpump for circulate cooling water after poweroff
Yes i do have room and plan for intercooler but i do log intake air and i is like 50 degres most and i newer drive more than 0,6 bar now and traction control takes down bost dynamicly depending on condition from readings from Abs rings, yes there is ready in ec for nitrius
http://youtu.be/G0H0SKXhglE
Here is some live data during driving and max bost is about .3 bar and traction works fine first part giving full trottle 1gear
http://youtu.be/EAfosVhMsbs
And here is a link to see when testing out the serve foregulating wing in turbo to reduce power when pressure go upp
Awesome!!!
Have you thought about lowering the compression ratio or using methanol injection??
Loving this bike build....
Wargen you are the Man!
BLS where are you??
I was deep into methanol early in project but engine works so perfect ether luck or wery good EC( MSIII)so no need for that when i go around ,6 bar no pre detonation lots of power, it just runs wery smoth, Im situated in Sweden smal town Visby on island Gotland, the best is that its road legal and dry weight is 165kg design goal was 150 but imposssible with turbo and ABS pump.
http://youtu.be/uOtGVc9yXbY
And here is a another cool stuff, an electronic display (bluetoth) but i like the original instrument more but this i first test with it so i forgot to change rpm display (to low).
i may have to make a trip to sweden just to see this bike lol
And I thought adding mirror extenders to my '09 was a mod.
Do you have any idea on the weight difference between the rc45 swingarm and the VTEC swing arm?
A very sweet project. If you intercool then use a water/air cooler with separate radiator electric pump.
I'd love to see some pics of the turbo exhaust & boost pipe plumbing.
CandyRedRC46
Ask Larry he scored an RC45 race one for Mr RC45 I believe. So I hope he has weights for standard (close to 5th gen) and the race unit.
Aimbot9000
My thoughts too!!!
There's a NR replica being built in Denmark
There's a NR replica being built in Sweden
And now a Turbo RC45 in Sweden!!!
[image: swedish-girls22919559-f899-42a7-a051-298]
CandyRedRC46
I think wiith the HRC wheel hub brake etc 1/3 ...
And price is x100
And HRC MkII kit swing with titan HRC hub brake etc is extreme difficult to source
And 3 version ( not singel arm ) is impossible i think never seen any for sale
HighwayStar2009
You folks are wery funny, thanks for all god words all of you
End of thread · 25 posts recovered Wayback Machine snapshot 29 Nov 2022
