Guhl Motors Ecu Flashing Discussion Topic.
9 posts Started 6 Nov 2014 Last recovered post 7 Nov 2014 Wayback Machine snapshot 8 Nov 2014
Hi guy's,
When you write Don Guhl from Guhl Motors for flashing, this is the response you get:
We have spent the last year reverse engineering the Honda flashing protocol and I believe that we are the only aftermarket company that can reflash the Honda motorcycle ECUs through the front connector without cutting or drilling into the ECU.   The standard 2010-14 VFR1200 (standard transmission and automatic transmission models) derestriction includes: Removing the top speed limiter Derestricting the throttle-by-wire for full power in all gears Installing a custom ignition map for full power in all gears Lower fan operating temp for more efficient operation   Options include: Raising the rev limit. We are not an engine builder, so we are not able to offer rev limiter advice. I can tell you that most people do raise the rev limit 500 rpm. Speak to an engine builder for advice. Disable the Exhaust Servo motor so that it can be removed without FI error codes   We are able to import Power Commander maps directly into the ECU so additional fuel controllers are not required. If there is a Power Commander map available for your configuration, we can use it.   We will be doing further development regarding ignition mapping and throttle-by-wire mapping to optimize performance as we dyno additional configurations.   The cost is $375 and that includes standard overnight return shipping to the continental US. International shipping is available at additional cost and the customer is to pay all duties/taxes.   The in-house turnaround time is normally 1 day.   To get this done, box up your ECU with a note with your name, phone number, return shipping address, and email. Ship it to: 4126 Oregon Pike Ephrata, PA 17522   We will give you a call to discuss how you want your ECU flashed and get your payment information. We accept Visa, M/C, or Discover. You can also send a money order along with the ECU, if you wish.   Let us know if you have any additional questions. Thanks, Don Guhl Guhl Motors 717-618-4212 www.guhlmotors.com
************************************************************************************************ The products and services by Guhl Motors are subject to change without notification.   Guhl Motors is not responsible for any property damage or bodily injury that may occur as a result of using this product.   The user assumes all responsibility for any damage that may occur to an engine and or vehicle as a result of tuning. Guhl Motors will not cover any damage that may occur as a result of using its products and services.   Guhl Motors' Products and services are for racing use only and are not designed to meet any emission level regulations and does not carry a CARB E.O. identification number, and may be illegal for non-racing applications. Check your local laws. ************************************************************************************************
I have let don flash my VFR1200F (manual) and for me the flash was worth it.
Few things to remember when doing this:
1. The ECU is the little back box located between the airbox and the steering, it's about 10 x 15 x2 cm in size, below is a sample picture:
[image: VFR1200F%20%2838770-MGE-644%29.jpg]
2. Put a paper with it stating the following: Name / Adress / PHONE!!! / Email, Don will phone you when the ECU is received and most of the time the caller-id isn't shown, so make sure you can receive those calls.
3. When export the ECU, outside USA only, make sure you mark it: TEMPORARY EXPORT and product-description SOFTWARE UPDATE, if you forget this you probably pay VAT and/or import taxes again.
4. Send your goods insured AND with tracking, else it's hard to prove if it got lost, and mail the tracking number to Don as well.
5. Beware the shipping costs, from e.g. Europe is mostly between 40~50 Euro to ship it to Don and about 75 USD to get it back.
6. If you didn't receive a call from Don after it has arrived, then call him yourself 2 to 3 days later, you could have missed his call for some reason, don't call if your shipment didn't arrive yet.
Mine was a HISS ECU, and there is no need to worry about HISS, his flash does not impact the HISS system.
Also, if you have some sort of restriction in place, he can remove it and put it to full power (for racing only as usual)
What he does with the ECU is not nessesary street legal and Don does not warrant it being street legal.
It's up to you if you use it or not. In Europe you are not allowed to modify mappings as it won't be legal anymore, yet most do it (Powercommander or something else like a Don-flash).
Don can inplement PC5 maps that match your configuration, if you are unsure of simply don't know: don't worry, Don will help you selecting/decide the best map for your configuration.
You are unhappy with your flash/map, no problem either: Don warrants the flash and will reflash it for free but the shipping-costs are always on your expense.
I have had a lot of talks with Don, never met him, but he's a very nice guy and knows his stuff.....once he's talking it's hard to end the conversation as he's a bike-enthosiast just like us.
If you let him talk, you will talk for hours about bikes with him :beer:
I'm not starting this topic about Pro's and Cons of Don his flashing, but just a place to talk about the flash and what you liked of hated about it, as well as how good your flash worked for you.
Or how fast your turn-around was.
To my knowledge, Guhl Motors is the only one that can flash this ECU, some claim to be able to do it but if you Google for it, not a single person reports that it worked.
Website of Guhl motors: http://www.guhlmotors.com/
Bassie, that's funny, the picture that you have posted is from the Company that has hacked up two of our ECU's (Carmo). :goofy:
I also agree that Don does a great job and is very honest and professinal. :beer:
I know, but it's the only good picture found in Google Pictures......so sad that ECU killers have good pictures :cool:
I think I've said enough good things about the re-flash as well as Don himself, but having communicated with him throughout the development of the DCT flash, I just can't recommend him highly enough. Great guy, great company.
No matter what bike I buy next, if it needs a re-flash it's going to Don. End of story.
Same here, and I was thinking of letting Don Flash my wife her CBR1000RR, but Don was against it, he stated that if her bike was powerful enough for her SHE SHOULD NOT FLASH.
Can't argue with that.
For her the CBR1000RR is fast and good enough......I have ridden the same bike but would flash it in a second as it lacks power for me.
However, the CBR1000RR is not comfortable for me, else I would have gotten me one, I'm too big for such a bike, ergo a VFR1200F suits me better but sucks with default programming.
Don't need anymore convincing. There is ample evidence from everyone who has had this done that they are happy with their outcome. Bike now stored for winter, ECU will be extracted and sent to Don by next week .... and then by late April 2015 when the snow melts I'll be able to enjoy. :sad:
did any of you guy who have done the reflash  have the bike remapped with a PC5 or Bazzaz ZF-i prior to the reflash ??? how does that work out,  should the pc5 or zf-i be removed ??   trying to put some $$ aside for Don this winter
I never used a PCV or anything else. The Don-flash does it all in 1 flash.
Never seen a bike upgrade that much for so little costs.
Mine was restricted, but Flashy his was full power and noticed the same.
This bike comes to life after a Don-flash.
Yeah too good to be trough....happily Don does this.....it is so good!!! :cheerleader:
I agree.I'm pulling my ecu out this weekend. Should have it sent next week. Getting cold in Canada now,so it's a perfect time for more mods.
End of thread · 9 posts recovered Wayback Machine snapshot 8 Nov 2014
