Hi
New member and the first post is one looking for advice, which I appreciate is a bit cheeky but still I am desperate to get this sorted and back on the road. I have been lurking for the last 3 months since I bought the bike, and appreciate the wealth of information from this site.
Bought an 03 VFR 4 months ago, VTEC version registered late 04 with 36k on it FSH up to 28k with receipts for the rest. No mods to the engine which would cause this issue as far as I'm aware, although a scottoiler has been fitted and I haven't as of yet got round to exposing the vacuum tubing to have a look at the joint. Aside from that its just handling/aesthetics mods like touring screen, heated grips, slip ons and an ohlins.
I had the valve check done on this 3 weeks ago by a big, popular and well established dealer with a relatively long wait list at times so I am confident that the work was carried out correctly and was going to carry out the rest of a service with a couple of mods like a power commander this weekend.
Riding home late last week in medium traffic, cruising at 70-80 with low rev's say 5-6k. See a low speed vehicle in front so prepare to got for the overtake by dropping it down to preprae to pull into the overtaking lane and accelerate. As I get on the power again having downshifted there is a momentary loss in power, followed by what I assume is an bang coming from the intake. It then rides terribly for about 15 seconds, I cant pull over at that time, so ease off the throttle, on the overrun it sounds terrible so clutch in and pull over. As I pull over engine settles down and idles but only on 3. There is also a fair amount of noise coming from the intake every fourth compression. Ease it home as Im 3 miles from the door and its midnight with work to go to. Get it home gradually nursing it and shortfiting below 5k.
Dimsmantled it today, take off the airbox lid and there is a smell of petrol in the filter as though it has been flooded by it. There is also a lot of rubbish kicked out of the rear near side air funnel. In addition to this there is quite a bit of this mustard yellow looking fluid splashing about in the intake housing for the tube going to the crank case breather. Looking at http://www.vfrdiscus...r-fuel-economy/it seems to be the fuel pressure regulator. But would that explain the terrible running for 15-20 seconds as described? Is there the potential for any long term damage? Ideally I dont want to take the heads of unless I really have to. In terms of how it was running when I rode it home, on three cylinders with low power. Approaching lights on the clutch in the engine would almost cut out so I heald the throttle at around 2k revs to prevent a stall. Its also running very rich and the exhaust stinks of fuel
