Opinions Needed And Appreciated
10 posts Started 20 Feb 2015 Last recovered post 20 Feb 2015 Wayback Machine snapshot 4 Mar 2015
Hello All...
I own a 2002 VFR800 non-ABS that I bought new in 2002. I have never had one problem with the bike and she currently has approximately 25,000 miles on the clock. In the last few years I have been getting into taking long trips with my VFR and love touring. Longest trip so far was 2,500 miles, 11 states in 6 days ;)
In July I am going to be riding my bike across country from MA to CA taking 2 weeks to do so (one way). I began searching the forum for any issues I should think of while prepping the bike for my trip. To my surprise I found post after post about problems with the VFR's stator, R/R and overheating wiring.
I am happy to say I have not had any of the stated issues. I have stripped my bodywork and checked every connection over the last few days and have not found any sign of melted wires / connectors etc.
Through reading this forum I also realized that I never had the product update done, although I remember being notified, that upgraded the stator and flywheel. My engine number is below the listed value that says I should have the underpowered setup although I have not had a charging issue over the years. (That I know of, no voltmeter installed)
So here's my dilemma... what to do before my trip.
1) Leave it as it since I've never had any issues and assume I won't during my trip
2) Upgrade stator / flywheel with kit 31100-MCW0325 (my research says this is the latest P/N) and carry a spare R/R
3) Upgrade stator / flywheel, R/R and install VFRness to cover all my bases...
I have the ability, tools and knowledge to do the work so cost would be parts only... and will be installing a Datel voltmeter regardless of the decided option :)
Anyway, I'm at a loss here and would be grateful for any thoughts... I'd much rather spend the money on the trip rather then the parts but obviously don't want to be stuck in the middle of the country either ;)
Thank you in advance,
Mike
#3, & search/read electrical topics this forum, I seem to recall issues with the main wiring harness.  Dubious grounding?
Searching and reading about the issues is what's led me to this post lol... I feel more educated about the VFR charging system now then I ever thought I'd need to be ;)
I'm just wondering why my bike has not seen any issues and worry I'll open up a can of worms if I don't leave well enough alone...
Me, I would let it be and ride. You have looked everything over and havent found any obvious signs right? Put the money to the trip and if something happens then it happens, at that point revert to plan B or C or D or whatever you need to do. You will have the voltmeter that can help catch things before they get to far gone. Anything can happen at anytime, it adds to the game if you ask me. Part of the journey is the unexpected......
you may be one of the lucky guys.....voltmeter is a good way to tell trends if you watch it for a fair while.  might be fine to just carry a small assortment of repair bits & tools.  rr is easy to have with you, go for it!
Keep in mind that the vast, vast majority of VFRs have not had electrical problems. Replacing working parts is a recipe for "I wish I left it alone"
Yup... no signs of an issue... the bike has been a typical Honda in my experience... Maintenance items only...
If the snow here in Massachusetts melts before July I hope to get some saddle time with the meter installed to watch what it does...
Doesn't sound like you run any/many accessories, fuse block, gps, elec grips, phone charger.
I'd say carry a replacement VFRness and  R/R (at a minimum a spare  three wire connector) since you know your way around a wrench. Wiremybike.com is your friend!
From what I've read, 6th gen Stators avg. between 40-60K mile lifespan. I'm aoproaching 50K with orig. Stator and R/R but replaced connector/wires between the two (smoked).
If your batt. is older, I'd say drop a new one in or carry a newer 1pd. Ion spare for back up. A volt meter install is a great idea.
I have a cigarette lighter plug direct wired to the battery that charges my phone... Only accessory I've ever used... Don't think a smart phone pulls too many amps...
Battery was new last year and I actually remembered to put it on the tender this year! lol
I like the idea of having some spares on hand... I plan to have a good tool kit with me so a few more items won't hurt.
Honestly I'd rather spend the money on Helibars rather then a stator upgrade... My 40yo wrists will appreciate those ;-)
Keep a spare R/r maybe. Install a voltmeter for peace of mind. You can pull 100W no problem. Smart phone is probably 20W at full bore. Think the limit is 150W-200W.
I might pull the stator cover and take a look. If it doesn't look like it's starting to burn up, I'd leave it alone.
End of thread · 10 posts recovered Wayback Machine snapshot 4 Mar 2015
