Alternative To Factory Fasteners
12 posts Started 30 Mar 2015 Last recovered post 1 May 2015 Wayback Machine snapshot 22 Jan 2021
I've toyed with the idea of replacing the factory ones for a while.
Has anybody tried the Dzus type ones?
Not sure how well they grab and.
Dzus fasteners are great, a half twist & they are open. The retained ones are best, as they stay attached to the fairing panel. Not used them on the VFR, but have on previous bikes. Made for racing where they need to remove & replace bodywork quickly !
HispanicSlammer has used this type.
Wish I would have seen this before I bought a kit of the factory type. :huh:
I've got Dzus for all my '99 front fairing fasteners. The upper ones that connect the sides to the front were simple using the clip on backs. The others required some creativity...
Just those are a simple upgrade and save time when removing the sides. Personally, I just wanted them all to be 1/4 turn. Couldn't manage tool-less, as the front V fairing is too recessed to fit D ring Dzus. Had to settle for 4mm allen head. Leaving the lower side fasteners as stock 5mm allen head bolts of course meant 2 tools required. So finally I got the sides as tool-less 1/4 turn Dzus specialty fasteners. (Long working length)
I've still got two of the plastic Honda fairing clips to contend with. Can't have a Honda without those! :goofy: :wacko:
Djeezus never fell of the cross did he? So them fasteners must be pretty good............... :cool:
KevCarver
Are there any on this website the same that you used?
Do you mean KurveyGirl? I got all of them from her, with the exception of the extra long ones I used on the side. They came from ebay and are intended for Honda (I think) Insight wheel covers, or something...
I believe I saw a complete set, looking quite fabulous, naturally, on Warwoman's Y2K, Possum .
Yeah, Warwoman looks complete, natural and fabulous.... :cool:
Yes, the Possum sports dzus fasteners. Love them!
Well I bought 10 of the DZUS fasteners with the black button head (the type a 4mm allen wrench is used with).
Unfortunately, I'll be returning them.
They're considerably smaller than the factory screws. A 4mm allen wrench is used with them. And with both being so small, they're difficult to use. I had to drill the holes they fit thru very slightly. They also seem slightly too short. The D-ring type is probably easier to use since you have more to grab onto. But I wanted abit cleaner look.
This is really disappointing. I've been wanting these for years.
End of thread · 12 posts recovered Wayback Machine snapshot 22 Jan 2021
